fans37402f40
Flight distance : 745236 ft
fans37402f40 Posted at 6-6 05:25
Does DJI endorse or have any kind of tracking device that can attached to a Mavic Pro (or any drone for that matter)? At this point I'm pretty hesitant to fly without one now....once you get burned, like most things, it get's your attention. I guess I've been lucky the last few years...flying six different drones and just now losing one.
Resolution for my disconnected or fly away drone was as expected when you don't have the product. Data analysis below obviously didn't tell me anything I already knew.....flying the unit as normal and it simply disconnected without any kind of indication there was a problem. Cache video taken just stops with no hint of malfunction and was under full control in ideal conditions.
DJI Response:
For your case CAS-3105993-R6X7W5, we have finished the data analysis, and the result is as follows:
1. The aircraft worked under GPS mode and responded to the pilot's command well;
2. Flight Time T=04:17 s, Relative Height H=37.2 m, Distance to Home Point D=381.3 m, the aircraft was hovering and then the record ended;
3. The Home point: 30.4626819 -97.6865133, the last point: 30.4609874 -97.6830552.
The record ended without any sign of abnormality, so we could not verify what happened afterward.
We truly appreciate your support for DJI. If you could not recover the product and consider to purchase another one, we can offer you a 30% off discount for Mavic Pro without the charger and remote controller. Please kindly send us the following information if you would like to accept the offer |
