Sony a6500 focus pulling? How to? w/new MCC cable
4442 13 2019-3-15
Trystin
Flight distance : 572142 ft
Hey!
So I just got the multi camera control cable in the mail and set it up with my sony a6500.
I tried using the focus wheel to pull focus and it seems like all it wants to do is zoom? Can someone help me on how to change the ronins settings or the camera settings to change this to pull focus instead? Would be greatly appriciated!
2019-3-15
Davidmartin
Flight distance : 578182 ft
With the new update you only need the MCC-C cable. Also put the camera in "REMOTE PC" mode where it says "USB" and deactivates the Control by Smarthphone option
2019-3-15
Trystin
Davidmartin Posted at 3-15 03:33
Ive done all these things, updated the firmware, updated the app, I have the MCC-C cable, but it insists on zooming, and in the camera control part of the app it recognises its a Sony camera as well, but the only option for camera control is zoom and its speed. Should I be seeing a switch to change the zoom to a focus pull?
2019-3-15
Davidmartin
is important put REMOTE PC, did you put it?
2019-3-15
Trystin
Davidmartin Posted at 3-15 04:13
In USB settings in camera? yeah I did
2019-3-15
residentx
Venezuela
Trystin Posted at 3-15 06:31
Same here!  still zooming after all of the above
2019-3-15
DJI-Paul
Flight distance : 41159547 ft
China
Refer to the camera compatibility list. A6500 isn't listed as being able to control focus. Sony's own tethering software doesn't even allow any type of manual focus to work.
2019-3-15
makerman
Switzerland
Same here with my A7r3. Only zoom. Also do not see any option to change settings of wheel in Ronin App...
2019-3-15
makerman
Switzerland
makerman Posted at 3-15 14:55
IT WORKS NOW!  Actually, I was using the MCC Multi all the time before
BUT:
1) it only works when AF is enabled on the lens and MF in camera.
2) I can not use my SmallHD Monitor at the same time with the MCC-C (goes blank)
Any suggestions for no 2) ?
2019-3-15
jacques_eloff
Flight distance : 2474974 ft
Davidmartin Posted at 2019-3-15 03:33
Hi @Davidmartin, I don't quite understand your comment here because MCC-C is not compatible with Sony A6500. Only MCC Multi works with A6500.
2020-1-10
jacques_eloff
Has anybody actually managed to get their Sony A6500 focus working on the focus wheel?
2020-1-10
jacques_eloff
Trystin Posted at 2019-3-15 03:46
@Trystin are you sure you are not confusing cables? The MCC-C is a USB-C cable and does not fit the Sony A6500. Perhaps you are referring to MCC Multi?
2020-1-10
jacques_eloff
Hi @Davidmartin, how do you "deactivate the Control by Smarthphone option". I can't find this option in Sony A6500. Please help.
Thanks,
Jacques
2020-1-13
MTuccillo84
jacques_eloff Posted at 1-13 02:55
Thanks,
by switching to pc mode only on usb menu
2020-1-17
