HereForTheBeer
Flight distance : 5381368 ft
yes this is normal the charger hub is a sequential charger which means it charges one after the other.
it will either pick whichever battery is most charged to charge first or will charger whichever battery was plugged in first if the charger was active during the time the battery as clipped in..
as for the controller battery being slow to charge off of main battery charger, kinda normal that it is slow, i think each USB port is 1 amp (2 amps total). if you want it to charge faster you can plug it into a higher power brick, most quality andriod phone chargers output 1.6 - 2.4 amps. ipad chargers do 2.4 amps. not sure how much this improves the charge rate for the controllers but in my experiance its not much faster, seems rate limited internally on the controller.. so plan on topping up over night or after every flight or something if its too slow
