SD Card Format on the SD Card Reader?
1167 9 2019-3-16
StardustGeass
Indonesia
What is the format type when DJI OP formatting the SD Card?Somehow, my phone (Samsung Note 9) can recognise it when I remove the SD Card and puts it on the SD Card reader, but my PC (windows, Surface Go) doesn't.
Need a way to dump the whole SD Card in a faster way, since using the given USB-C adapter to phone, is very slow.
Having the file put into the phone and then into my PC is a lot burdensome.
2019-3-16
Curt1591
Thailand
Did you use the Pocket to format the card? Can you format it with the Surface?
2019-3-16
DJI-Osmo-User-1
For a card up to 32gb it’s fat32: for a card over 32gb it’s exfat.
2019-3-16
StardustGeass
Indonesia
Curt1591 Posted at 3-16 02:34
Yep, I use my OP to format my card.
Well, I suspected it was an ExFat as well, but somehow my Surface Go don't want to recognize it, either using a S card reader through the USB-C port, or even insert it thoroughly to the SD Card slot on my PC as well...
2019-3-16
DJI Stephen
Hello and good day StardustGeass. Thank you for reaching out. If the SD card is formatted with the DJI GO app, the SD card that is less than or equal to 32GB should be formatted in to the FAT32 file system while the SD card that is larger than 32GB should be formatted in to the exFAT file system. If the SD card is formatted on the computer, the SD card that is less than or equal to 32GB should only be formatted in to the FAT32 file system. The SD card that is larger than 32GB should only be formatted in to the exFAT file system. Thank you.
2019-3-16
StardustGeass
Indonesia
Sorry for bumping old thread, but I think it is better than just create a new one with the same problem.
Turns out, until now, I cannot make SD card used by DJI OP to be readable on any windows devices (Laptop & PC, tried on several of them). Tried several SD Card reader but doesn't work as well.
It is still readable by my Android device though, so I can at least move the files there. Also, my WD Wireless Passport (gen 1) can read and move the files inside, so it is a big help. But, with very slow data transfer speed (around 2MB/s I think?), I really wished it is possible to just use my USB-C SD Card reader for faster transferring file.
Anyone having the same problem? Or is it just me?
2019-5-18
Ray-CubeAce
StardustGeass Posted at 5-18 04:39
No. I take the SD card out of the Pocket and into a card reader for my Windows tower case PC.  I have no download problems at all. My PC can 'see' the card and contents.
2019-5-18
John Walker
Ray-CubeAce Posted at 5-18 09:45
Ditto - I've had no problems reading the OP card via a card reader connected to my PC  (Win10)
2019-5-18
Ray-CubeAce
Just re-read your comment.  You can't use a standard SD card reader. It must be at least SDHC or SDXC compliant.
2019-5-18
StardustGeass
Ray-CubeAce Posted at 5-18 14:52
I'm using the one compatible with.
Before using it on my OP, I can access my SD Card without problem.
2019-5-24
