AlansDronePics
Flight distance : 814751 ft
Guernsey
2 things.
First, you do know there is a setting in GO4 to direct the save from phone to SD card. However this the place where low res images from the cache are stored. You mention blurred and poor images, if you are getting them from here, that is the reason.
You can't save to the GO4 App, just phone memory, SD card on phone if it has one, or the SD card in the drone where all the proper, full quality images are saved.
Next, the SD card in the drone will show up on the screen of your device, if it is installed properly. Is it showing up?
You can format the card in the drone, the best place to do this, because it only knows the right format and you cannot make a mistake. If the card worked previously than it was probably the right speed or class.
If you formatted on the MAC then you might not get the cards to work anywhere else.
If several cards won't work then suspect the drone is at fault. |
