Brand new Mavic air Huawei medapad. T3 7", no video feed
2809 8 2019-3-18
Adrian28
Hi guys
I am new to drones and have just purchased a Mavic Air and am trying to use a brand new Huawei media pad T3 7" with it.
Currently all seem to work ok apart from the video feed i.e. There is none.
Does anyone use the same tablet, is there a work round to enable it work function correctly or have I made an error purchasing it.
I don't have a smart phone I can use with the mavic ( company phone and cannot down load any "apps" ) so was trying to find a cheap solution ( don't want to spend loads of money on a smart phone I will only use on the mavic.
Thanks in advance Adrian
2019-3-18
DJI Stephen
Hello and good day Adrian . I am sorry to know that you are having issues with the mobile device you are using on your DJI Mavic Air. Upon checking  Upon checking the mobile device Huawei medapad. T3 7. I am sorry to say that the mobile device that you are using is still not recommended for your DJI Mavic Air as of the moment. Actually, there is a  possibility that the Huawei medapad. T3 7 will work, however, since it's not yet optimized with the DJI Mavic Air and with the DJI Go 4 application we cannot guaranteed the stability of the Huawei medapad. T3 7 when in use with the said device and with the said application and if this will work all the time while using the specific device.  We highly suggest you use the compatible device that was listed on the recommended mobile device list below to avoid any problem. Thank you.
2019-3-18
s_trendafilov
Flight distance : 43133 ft
Bulgaria
Hello, Adrian28. Try using a different (quality USB 3.0) cable - try the one that came with your Mavic. Also, if it helps, please give your feedback how does the T3 perform with the Go4 app.
2019-4-9
Ahmed Hussain
Flight distance : 1339761 ft
Kuwait
Some cables are only for charging and you need to make sure you are using a data cable not the one only for charging. You can check by connecting the mobile to a computer and transfer some files.
2019-4-9
glynrdav
South Africa
Hi Guys, i saw that the Huawei MediaPad T3 was on the approved list, so i bought it to use with my Mavic 2 Zoom. I cannot get a consistent connection and when I do, there is no Video. I have downloaded the aircraft to 1.00.300 and tried various version of DJI Go 4 but with no luck. Is it possibe to make this work, or have a different tablet is required. Any ideas please and recommend another 7" tab?
2019-5-1
Aerial-Image
Flight distance : 1452408 ft
Hi Adrian,
I use the Huawei M3 Mediapad for my MavicAir and P4Pro - but the T3 one should be able to work, have you the usb settings set correctly to send the video data feed.?
2019-5-1
BMK1
Make sure you are using a type 3 usb cable it will have blue on the usb end.
2019-6-7
djiuser_4YXrbn1EHLxr
Download DJI Go 4.1.9, the Huawei T3 works perfectly with that. Make sure you turn off auto updates on PlayStore though.
To download just Google DJI Go 4.1.9 APK and download from a site.
2019-7-27
Martyzion
Flight distance : 1976608 ft
The Huawei T3 does work if you use DJI Go 4.1.9 but I believe that older version of the app does not support the Air.  It does provide video if you use a Pro or a Spark.
2020-8-10
