ff22
roamer105 Posted at 3-19 14:00
Interesting observation: It turns out the flight has been recorded but with a bogus date of January 18, 2013 !! --------- DJI please shed some light on this!! Thanks!!
I will re-test this by turning off the controller prematurely to see if it relates to that. It may be that GO4 upon creating the file initially puts in such a date (weird) and will updated to the correct date when the file is closed and for some reason is unable to correctly finish and close the file -- just a guess.
Others have been reporting that their controller won't hold the current date and gets the date you saw. Even resetting the time/date has not fixed it for them.
I just powered mine up to check battery level. The date is showing correctly. The last time I used it, images had the correct dates. |
