Tracking available for 4K@50fps but not at 60fps?
2434 5 2019-3-19
DJDream
Israel
Why it is not available for 4K@60fps as well  ?
2019-3-19
Hi DJDream, Active Track is not available in 4K,60FPS because the CPU in this frame may get overloaded and affect the tracking performance, sorry for the inconvenience and appreciate your understanding.
2019-3-19
DJDream
Israel
DJI Mindy Posted at 3-19 19:58
Hi Mindy ( btw - I am a fan of Kick Ass movie too :-)  )
Thanks for this info.
Is it the same reason that the "Superfine" option isn't available at 4K@60fps? If so, maybe you can consider adding this feature (Superfine) for 4K@50fps only?
I think that it should be awesome to have it for a higher framerate than we have it now.
Cheers!
2019-3-20
Udo13
Flight distance : 257188 ft
DJDream Posted at 3-20 00:12
Yes it is.
2019-3-20
DJDream
Israel
Thanks Udo,
Is the "Superfine" option available for 4K@50fps?
Wow, I wasn't sure it is available for lower fremerates.  Have you tested it? How it is compared to the "Fine" (only) option?
2019-3-20
A superfine video/picture has higher definition and less noise, but the camera could generate excessive heat and the battery will drain quickly. Therefore, it is only available in 1080P 24/25/30FPS and 4K 24/25FPS. Appreciate your understanding.
2019-3-20
