Betamace
Flight distance : 2133 ft
I have several 2 amp chargers and using a USB power meter, I never see a current draw exceeding 300ma when charging my R/C. The charge rate of the R/C battery is regulated within the R/C, so regardless of the charging adapter rating being 1 or 2 amps, you will not be able to accelerate the charging time. If you charge your display device simutaniously with the R/C through a USB hub, a 2 amp adaptor would be prefered. And, there are larger gauge USB cables available that will insure the USB cable is not bottle necking the charge current. |
