Fine 60K@60fps vs Superfine 4K@30fps - Quality Comparison?
2095 6 2019-3-20
DJDream
Israel
Hi guys,
Does anyone run a such quality comparison between the two modes mentioned?
I bought the Osmo Pocket especially for the 4K@60fps option but according to the DJI developement team this resolution and framerate is very very limited which is dissapointing big time...
- No Object Tracking option at 4K@60fps..
- No Superfine option at 4K@60fps...
So I wonder if maybe the 4K@30fps quality is better than the 4K@60fps ...
What's your thoughts on it ?
2019-3-20
djiuser_3PbFsVin0SFQ
Cannot find the post but there was one who compared 4K30P normal vs superfine and conclude there was no really noticable difference.
2019-3-20
Wiz33
Flight distance : 35994 ft
I shot over 350GB mostly in 4K@30 for a month on vacation and results are much better than I expected even before the latest firmware update. You can see my unedited and non-graded result here. There is one clip at 4K@60 from a fast moving train.
https://forum.dji.com/thread-177399-1-1.html
P.S. you don't really do the OP justice watching the clips on a computer monitor (though they do look good) but I would say they look damn impressive on my 65" Samsung QLED. 2 of my friends have bought their own OP after seeing my clips on my TV.
2019-3-20
DJDream
Israel
Wiz33 Posted at 3-20 07:49
Amazing clips but I don't understand why don't you use the 50/60 fps frame rate that can give you smoothness and a better quality.
2019-3-20
Tide
South Korea
DJDream Posted at 3-20 08:20
50/60 gives you more smooth looks and slowmotion capablity but it is not necessarily higher quality.
You can get smooth looks with right shutter speed with ND filter in any frame rate and higher frame rate cut down more light and its higher compression can lost more detail than lower frame rate.
It is all come down to preference and the right situation.
2019-3-20
Wiz33
Part of it was clip size and battery life. I only had a 128GB SD for the trip and was too lazy to copy whatever I shot onto my laptop everyday ;-P and I also don't want to have to carry a powerbank all the time.
2019-3-20
Cool h
I used to have superfine option in 30 fps now it only works under 25 fps, anyone has the same issue with me?
2019-3-20
