Kevin Vun
Malaysia
DJI Tony Posted at 2019-3-20 13:43
Hi, we're sorry to know about this situation. May we know if these images came from the SD Card of your aircraft? If yes, have you tried to reset the camera settings of your aircraft? I would like to clarify if this blurry would occur on the daytime or if there's enough light? The blurry image may occur when flying your drone in the night time or on a cloudy day. Within this situation. the blurry image cannot be voided, however. this matter occurs when the exposure time is longer than 10 minutes. You can also set the camera to M mode to reduce the exposure time, but the image quality will decrease. For example, in A mode, the shutter is 100 and ISO is 100, then you can set the shutter to 200 and ISO to 200 manually. Please let us know the latest progress. Thank you for continued support.
I also got the same problem as him, but my photo is taken not from the sd card, is it better if i take the photo from Sd card? |
