fans10b139d5
Flight distance : 949619 ft
DJI Paladin Posted at 3-20 11:14
Thanks for your prompt response. For Android devices, please turn on "USB debugging." For Samsung devices, please ensure that the connection mode is set to Media (MTP) Camera (PTP) Mode. Open DJI Go 4 APP, tap on "Me" icon, tap on the cogwheel on the top right and then enable USB Developer Option (USB Debugging). Also, try to back up your files and sync your flight records and then reinstall the APP. Kindly remove the cable on the left side even if you are not connecting it to your mobile device and then connect to the bottom port. Man, you're the n 1 executed usb debug and reinstalled dji4 app
Problem Solved
Now, the problem is on the Usb mini port
https://drive.google.com/file/d/1uI2JYD3eifhQYinG7nyYuMhdh-bdEfma/view?usp=drivesdk |
