Ground Station Pro only allowing me to fly at 100meters
1516 4 2019-3-21
fans779679d1
Flight distance : 4650394 ft
Hi would love some help witha problem I am having.
I have used Ground Station Pro a few times & found it great.
I updated it to the latest version & now I am having a problem.
everytime I try to fly a simple way point mission, the drone willl not fly at my entered height.
For example on both my Phantom 4 pro & inspire 2 , I entered the mission simple mission just flying between 2 points, to fly 300m away to the next way point at a height of 12meters.
When I start the mission the drone climbs past the 12meter mark & keeps going to 100meteres in alituide. Once at 100meters  it will do the misssion, but  at the height of 100meters, even tho I have entered in 12meters.
I have tried using difrent heights & difrent loacations but still keep getting teh same problem,
any help would be great, I have a job on tomorrow where I need it, I had the same job today but was unable to complete it at such a height.
2019-3-21
Keule
Flight distance : 3733015 ft
Hmmm, have u tried another Waypoint app? e.g. Kittyhawk or similar?
2019-3-21
fans779679d1
Keule Posted at 3-21 08:43
HI, I have lithi but that dosent give you full camera functions on inspire 2, might have to try another app, but I need mission ton repeat the same flight in years time, so its important to have it repeatable .
2019-3-21
Keule
fans779679d1 Posted at 3-21 10:41
Try Hangar's Autopilot - works well with an I2.
2019-3-21
fans779679d1
so I figured it out, when planing the mission on GSP it defaulted my flight heights to 100m altitude for 'Each point' , & when I went to change all points  flight heights to a a lower number, 'All points' button does to change the individual points height, so even tho you think its changed all points to say 20m, it will only work if you change each point height individually to 20m. so that it! might just of been me being a bit slow, but either way it work !
2019-3-25
