mixchief
Flight distance : 182057 ft
Aero-Drone Imagery Posted at 3-30 16:53
I have had no issues with the I2 using this lens. I will say that I am not flying a lot of videography jobs, especially that require any real speed that would test the limits of the X5S gimbal. My method of balancing this lens is the balancing ring that was designed for the lens, with a UV filter on the end of that, seems to work well. Hope this info helps, feel free to contact me if you have any other questions.
Happy and Safe Flying!
Thank you for your insight, What size is the UV filter, maybe that's all I'm missing. SI fly me I found a lens hood on eBay that is a perfect match for this lens, but it would not fit with the balance ring, for some reason and it's really strange, or maybe not, the balance ring's threads seem to be a different size than that of the lens itself. but it was all for naught anyway as this hood is very wide and I'll have to screw it on after the lens extends and must be careful to remove it before the lens retracts |
