Altitude unlock??
1442 2 2019-3-23
djiuser_W1W1q8waS3Su
Flight distance : 29400 ft
Ukraine
Hello, tell me if I issue these two licenses Will I be able to fly to a height of more than 3.000 m ?? Does the DJI GO program itself tighten my licenses ??
2019-3-23
Labroides
Flight distance : 9991457 ft
NO .. the "licences" won't allow you to fly to 3000 metres and the drone won't fly past 500 metres.
If you are flying in the Ukraine, the US FAA certification will be of no use to you.
2019-3-23
DJI Stephen
Hello and good day. Thank you for reaching out and for the inquiry. Labroides is correct please refer to post #2. In addition you can set the Max Flight Altitude on the Main Controller Settings, the range is 20 to 500 meters, the default setting is 120 meters. If you need to fly beyond 120 meters, you need to agree on the agreement to the change the settings. And the max altitude enabled is 500 meters AGL, you are not able to exceed this limit. Thank you.
2019-3-23
