RicardoGray
Flight distance : 4356421 ft
It is very hard NOT to get nervous when first learning to fly your phantom. The RTH is something a lot of users do not completely understand and can be nerve racking for sure. Like Geebax has already said, the multiple button presses can undo what you are wanting. Again, understanding how the RTH feature works is important, and you might want to read up on it a couple times. It is hard to be patient when you don't know where your phantom is, but you have to have faith! It will return in most cases. Remember if it is out of your site and /or lost it's signal from your receiver, it will trigger the RTH after a predetermined amount of time, without you doing anything. When it gets close enough to regain the signal, your pressing the RTH button will cancel the RTH on you. The best thing to do in my opinion is if you lose signal, or has completely gone out of your site, remember there are a couple of built in safeguards...……..after a short interval on lost signal it will trigger the RTH, and if you haven't turned off the smart return to home, it will trigger the RTH when the battery level reaches the point to where it thinks it can't get back home. Best advise might be to practice the RTH feature while keeping the phantom within sight so you know what to expect. |
