ChrisMac12
Flight distance : 562336 ft
I used my Mavic Air last in February with no problems. I fired it up last night and noticed that the gimbal was locked in an almost straight forward position and was unresponsive to the wheel on the controller.
Today, i attempted gimbal calibration and it says completed normally. When i turn on the drone the gimbal doesn't do any side to side motions, it simply rolls straight down, then straight up until ready to fly and then faces straightforward and is unresponsive.
Also, since i've had the drone, i've had to update the firmware every flight (it stays at .0500 and i update to .0560 every....single....time)
I downloaded DJI assistant to try and update the firmware that route. When i turn on the drone, after connected to the PC, it is recognized as a hard drive and the DJI assistant doesn't see the drone.
I'm at a loss for what else to try to get my issue resolved
edit - also, when the drone is on and connected to the remote, when i manually move the drone and pitch it up the camera maintains a forward aim (as if pitching down)
