split video
1045 9 2019-3-29
Picanoc Jack
Flight distance : 10310322 ft
why is it that if I record from the time I take off the video comes back to me in 2 videos,  eg 0001  0002 ? what am I doing wrong? is there a way I can just get the one complete video?
2019-3-29
raven swe
Flight distance : 517936 ft
Sweden
from what I read it will only record in chunks and not a single length video, I use a video joiner if I want to make a full length video
2019-3-29
Picanoc Jack
raven swe Posted at 3-29 05:04
thank you for your input, that's what I usually do however I would like to find out if there is a way that I can avoid that procedure and get the video in only one complete piece.
2019-3-29
Woe
Flight distance : 4129268 ft
In the settings try changing the video cache from 2g to a higher number.
Mine is set to 4g
2019-3-29
Picanoc Jack
Woe Posted at 3-29 05:13
Mine is set to 4g
will try that Woe thanks again.
2019-3-29
PS013
Flight distance : 3579409 ft
Also, note that the Mavic pro supports 2 files systems FAT32 and EXFAT ( according to the DJI web site https://www.dji.com/mavic/info#specs )
If your SD card is formatted in FAT32, the maximum file size is 4GB ( that is a limitation of the FAT32 file system) and the Mavic will create a new file each time the filse size reaches 4GB.
2019-3-29
Woe
Picanoc Jack Posted at 3-29 05:32
No problem. Keep us posted
2019-3-29
DJI Stephen
Hello and good day Picanoc Jack. Thank you for reaching out and for the inquiry. The maximum file size of FAT32 is 4GB. Hence, a file that is larger than or equal to 4GB will be divided, otherwise, the file may be lost or abnormal and cannot be read. Although exFAT allows a larger file size, the larger file may be damaged due to abnormal power-off and SD card removal, or even cannot be recovered. So the storage of the camera is 4GB regardless of the file systems. So it is normal the video will be split if it reaches 4GB. Thank you.
2019-3-29
Picanoc Jack
DJI Stephen Posted at 3-29 08:40
thank you Stephen, and while I have you on the line did forum have a glitz that I just could not connect to it in the last 20 hours or so?  Work good this morning but had a hard time connecting to it most of yesterday.
2019-3-30
DJI Stephen
Picanoc Jack Posted at 3-30 04:55
You are very much welcome Picanoc Jack. As of the moment I do not have any information if there was a glitch that happened on DJI Forum hours ago. Thank you for bringing this to our attention. Thank you for your valued help and support.
2019-3-30
