Capturing telemetry data along with video
6964 5 2019-3-29
mikeydoo
Hi
How do I go about capturing telemetry data with the video, and play it all back together? I have downloaded some of the telemetry from the Mavic 2 using Assistant 2. It downloaded as a .dat file. If this is the only way to capture telemetry data, is there a way to use it with the video (Pilot, Go 4, something else)?
Thanks...
2019-3-29
Keule
Flight distance : 3733015 ft
Use Racerender
That'll do the trick,
2019-3-29
BudWalker
Flight distance : 5966247 ft
Assistant 2 will create a .DAT that is encrypted. You'll need to use the .DAT or .txt from the DJI Go App.
2019-3-29
mikeydoo
BudWalker Posted at 3-29 13:43
Thanks BW
If I'm using another app to perform the mission (Pilot or Go 4) do I then run Go and use it to download the telemetry?
2019-3-29
Hi mikeydoo, if you enable the Video Caption in Camera Settings for Mavic 2, there will the SRT files to be generated separately after the video is recorded, which records the FrameCnt (frame number), DiffTime (time difference between the current frame and the previous one), ISO, Shutter, EV, GPS coordinates (after the firmware V01.00.02.00) and so on.
Please correct me if I understand the post wrongly.
2019-3-30
BudWalker
mikeydoo Posted at 3-29 14:06
Thanks BW
The Go App will record the .txt and a tablet version of the .DAT. If it's an Apple tablet then you'll need to use iTunes to retrieve those log files. If it's an Android tablet there are several file transfer apps that can be used to retrieve the log files.
Other Apps will have their own version of log files.
2019-3-30
