OP : Charging Options/Quaestions
664 1 2019-3-31
DJDream
Israel
Hi all,I have two questions related to the OP functionality:
1.How it is possible to stop the OP to charge the phone while the phone is connected through the Universal USB-C connector (Android) ? This kind of connection is draining the battery of the OP without any reason. My phone battery has a 5500mAh capacity.
2.How it is possible to stop the charging of the OP while I'm transfering files to a PC through the usb-c bottom connection. I am pretty sure that charging the batterry in parts and not fully may lead to a shorter battery life of the OP in the future.
Thanks,
DJD
2019-3-31
DJI Stephen
Hello and good day DJD. Thank you for reaching out and for raising this inquiry.  The DJI Osmo Pocket will charge the android mobile phone at 5V and 500 mA. This is regulated by the Android Open Accessory (AOA). As the DJI Osmo Pocket keeps charging to the mobile phone, the Osmo Pocket's battery life will be slightly reduced. To make the DJI Osmo Pocket work longer, it is recommended that the Wireless Module be used. Thank you for your support.
2019-3-31
