Have you seen this before?
848 3 2014-11-10
ffoulem
When I fire my Phantom Vision +  up, one of the rear lights blinks green (on the leg left of the battery), while the other blinks yellow (on the leg to the right of the battery) - slow synchronized blinks. I can't find this combo in user manuals. I don't know what to make of this. Any ideas?
I've disconnected the GPS unit and tested again with the same results.
The Wi-Fi works, as well as the camera feed.
I'd appreciate some guidance.  Thanks!
2014-11-10
DJI-Sophie
China
It seems the LED module missed its pure color, please send it back for repair.
2014-11-10
ffoulem
What would be the indicator if one motor had a failure?  At this moment, the unit will not start; I'm suspecting one motor.  Would such a LED combo indicated this?   BTW, when I power up, the LED on both back legs cycle red-yellow-green before settling on one being yellow, the other being green, so I know the proper color LEDs are working.
2014-11-11
DJI-Sophie
China
Hi ffoulem, there is no LED combo which would indicate the motor failure. If the LEDs are working normal, while yuo are unable to start the Phantom, please connect to the Assistant to check is there any error message, also, please calibrate the remote controller again.
2014-11-11
