Firmware Update V 01.06.00.20
123Next >
8302 86 2019-4-2
Gulfstream
Flight distance : 98996 ft
Firmware Update V 01.06.00.20 for the Osmo Pocket Released via the Mimo App
1. Added a tip prompt and display icon when connecting an external microphone.
2. Added option in settings to turn off the beeping sound when pressing buttons.
3. Optimized UI of Pro Settings.
4. Optimized Face Detection.
5. Reduced Focus Pulsing when switching between scenes.
* Firmware Size: 99Mb
2019-4-2
NeonAura
Downloaded but when prompted to install, it said "Device not connected" though it was?
2019-4-2
KBridge20
Any update notes available yet?
*Edit*
Just found them.
2. Added option in settings to turn off the beeping sound when pressing buttons (finally)
3. Optimized UI of pro settings.
4. Optimized face detection.
5. Reduced focus pulsing when switching between scenes
99mb download
2019-4-2
AmaDee
Was able to download but not tested.
Wish the 4K/60fps file transfer was addressed.
2019-4-2
CemAygun
Flight distance : 810 ft
Unfortunately no change in timelapse intervals or addition of ISO limiter. Active track still keeps the subject too high in the frame...Honestly apart from the option to disable the beeps I cannot see any difference.
The claimed improvements (better focus etc.) need to be tested of course...
2019-4-2
Wiz33
Flight distance : 35994 ft
NeonAura Posted at 4-2 05:53
Loose phone connections? Did you try again?
2019-4-2
Udo13
Flight distance : 257188 ft
CemAygun Posted at 4-2 07:02
Unfortunately no change in timelapse intervals or addition of ISO limiter. Active track still keeps the object subject too high in the frame...Honestly apart from the option to disable the beeps I cannot see any difference.
I feel the same way. I am very disappointed.
2019-4-2
Oh-no
v01.05 skipped .....
2019-4-2
DJDream
Israel
Reducing focus pulsing - thanks for hearing my complain and fixing it. I'll check it out.
2019-4-2
NeonAura
Wiz33 Posted at 4-2 07:04
I did and now it comes up with the Mimo screen controls (but now I don't get a prompt about the firmware) so it recognizes the connection.  Is it time to reformat my micro card?
2019-4-2
DJI Stephen
Hello and good day Gulfstream. Thank you for sharing this information with us today. Great find and thank you for your valued support.
2019-4-2
DJI-Osmo-User-1
NeonAura Posted at 4-2 07:52
When connected to Mimo press the home icon and the update should show
2019-4-2
TheCameraGuy
Flight distance : 40866 ft
Well, I get told the download failed, network not available.
tried 2 different networks. both wifi.
Typical
2019-4-2
Arc Light
Can anyone tell me where the option to turn off beeps is located? I have the latest version of the Mimo app, but I'm having a hard time finding it.
2019-4-2
TheCameraGuy
I also tried using the wifi/bluetooth connection. still says no network connection.
Oh well, I didn't see anything in the firmware update that rocked my world. I guess I can do without it.
2019-4-2
lummox
To disable the beep -, from main screen, swiped down to get into settings (the gear icon), go to the far right (swipe left?) .
2019-4-2
Gulfstream
Arc Light Posted at 4-2 09:28
Can't do it from the Mimo app - on the Osmo Swipe Down to get the Gear Icon, Press it, then swipe left 2 screens, you'll see Key Tone. That is the setting to turn off.
2019-4-2
Stuge234
India
Same ,I couldn't find much of difference
Except  switching beep  on/off and Time remaining on your card ..Which used to be like 59.59 + ..Now ,it shows 65 minutes left .
- Still waiting for atleast 4 timelapse intervals
- 4k option while recording Timelapse /motion lapse .
- 9 x 9 =330 degree panorama option
2019-4-2
Stuge234
India
Use  the device to switch it off under settings menu .
2019-4-2
TheCameraGuy
So I erased my memory card - format. It still has a network issue. Then I did a reboot on the camera and the iPhone X, nothing. Then I rest the OP to factory settings and still nothing.
So, now I'm back further than I was when I started.
Does anyone have a suggestions. I don't even get the new download firmware notice on my screen.
HELP!!
2019-4-2
NeonAura
It must be connected because it's comes up camera mode; but no new firmware indicator.  I tried putting in a new micro card which didn't ask to format but did allow me to take a photo and save it so that seems ok.
2019-4-2
NeonAura
DJI-Osmo-User-1 Posted at 4-2 09:07
OK, I turn on the Oslo and a vertical blue/green line tells me its connected.  Then a white box come up and instantaneously disappears.  The only thing I could glean is USB.  Right now Osmo needs recharging.   Thinking I may try again when I can plug the USB port direct.
I checked my firmware info and it's at 01.04.  Would that have something to do with it?
2019-4-2
ManchesterOP
anyone seen the 'Added a tip prompt and display icon when connecting an external microphone.' looked on the OP and in the MIMO app nothing?
2019-4-2
NeonAura
I did that but it just went to tutorials.  Did not see anything about firmware.
2019-4-2
NeonAura
2019-4-2
Joemar7
American Samoa
TheCameraGuy Posted at 4-2 11:17
I had a similar issue on the previous firmware until I manually updated the Mimo app from the App store.  I'm not sure if this may help.  I'm at work now so I haven't tried the new firmware.  Are you connecting directly to the phone with the phone adapter?
2019-4-2
Arc Light
Gulfstream Posted at 4-2 10:39
Can't do it from the Mimo app - on the Osmo Swipe Down to get the Gear Icon, Press it, then swipe left 2 screens, you'll see Key Tone. That is the setting to tun off.
Thank you all for the info about the beep control, silly me I assumed you could do it from the app, maybe that will come in a future app update.
2019-4-2
Ray-CubeAce
Just updated with no problem. It took approximately three minutes to complete. Around the 62% upload mark, the program said it would restart the Osmo Pocket which happened around the 70% upload complete mark. At 80%, the Osmo Pocket seemed to shut down again and shortly after I got an 'Upload Complete message.  Firmware in Osmo Pocket indicates updated firmware but can't find anywhere on the App or in the Osmo Pockets screens as to where to turn the beep on /off.
[Edit]
Having to recharge my Osmo Pocket now before trying out adding an external microphone. Still can't find a beep kill switch.
2019-4-2
NeonAura
Joemar7 Posted at 4-2 11:46
My mimo is latest - 3.0 but it did that update automatically.
2019-4-2
Anton U.
Russia
Now OP is better than perfect. Thanks DJI. I appreciate your “quick” responsiveness.
2019-4-2
Gulfstream
Ray-CubeAce Posted at 4-2 12:39
[Edit]
On the Osmo: Swipe Down to get the Gear Icon, Press it, then swipe left 2 screens, you'll see Key Tone. That is the setting to turn off.
2019-4-2
Ray-CubeAce
Found the key-tone switch.
Swipe down to gear symbol. Press gear symbol. Two swipes to the left.
It works.
2019-4-2
Ray-CubeAce
Gulfstream Posted at 4-2 12:45
Ha! beat me to it
2019-4-2
Ray-CubeAce
Is it just me or does the phone screens' gimbal control seem more responsive?
2019-4-2
NeonAura
NeonAura Posted at 4-2 11:31
I think it did the download as it did the percentage countdown but then it wouldn't let me install.  That's the point I'm at.
2019-4-2
NeonAura
Oh-no Posted at 4-2 07:38
I wonder.  I'm at f01.04 and I thought I was constantly checking for firmware updates.
2019-4-2
Ray-CubeAce
Well, at least it goes into the parked position super quick now.
2019-4-2
hedac
cannot install fails at 52% everytime...
it happened to me with the first firmware update... but some days after, and with another phone, it worked and then I could also update to 1.04... but this time with 1.06 again with the same problem to fail at 52% install.
2019-4-2
GoPro King
Flight distance : 578799 ft
Anton U. Posted at 4-2 12:45
lol, that's what you think...……………….LMAO
2019-4-2
Curt1591
Thailand
hedac Posted at 4-2 14:17
Often, with new releases, the servers get flooded. Since none of the updates are life changing, just wait a while and it should lighten up.
2019-4-2
123Next >
