IMU calibration issue. FIXED
1256 21 2019-4-2
sparkdrone
Flight distance : 9593 ft
I used to have an issue where I could not finish IMU calibration but it was fixed. I just had to turn it another way.
2019-4-2
sparkdrone
Are there any suggestions about how to fix it?
2019-4-2
nilanjan118
Flight distance : 636663 ft
Japan
Are you keeping an eye on the pictures on the app which show the way you should turn the drone at each step? I don't remember exactly but there are 2 consecutive steps where the pictures seem identical and it confuses a lot of people. Make sure you notice the pictures changing closely and do as the app says.
2019-4-2
sparkdrone
nilanjan118 Posted at 4-2 17:26
Not sure if I turned it the right direction maybe I should try it again?
2019-4-2
Rustic17
Flight distance : 2733760 ft
Follow the pictures exactly...be on level surface and totally away from any metal...like out in the yard (away from concrete with rebar).
2019-4-2
nilanjan118
Japan
sparkdrone Posted at 4-2 17:33
Yes, please do. And just as I said, keep a close eye on the app to see the illustrations changing. There is one step where users don't see the picture changing as the differences are minimal. They don't turn the Spark at this step and find themselves "stuck". I have seen such posts in the past and get the feeling that you are doing the same mistake. So please try again with this in mind. Hope it helps.
2019-4-2
sparkdrone
nilanjan118 Posted at 4-2 17:42
OK thank you I will try to look at the pictures very closely.
2019-4-2
sparkdrone
Rustic17 Posted at 4-2 17:40
Thank You! I was very close to metal when I tried doing it but just as nilanjan118 said I also might have missed the picture change so I had to turn the drone.
2019-4-2
DJI Tony
Hi, we're sorry to know about the situation. Like what others mentioned, did you manage to follow the steps on the DJI GO 4 app during the calibration? Please ensure that there are no interferences during the IMU calibration to prevent further problem during the calibration. You may refer to our video tutorial below for further check. If you will encounter any error messages on the application, please let us know. Thank you for continued support.
2019-4-3
sparkdrone
DJI Tony Posted at 4-3 13:32
https://www.youtube.com/watch?v=z_pfcHyHFm8
Thank you for the video.
2019-4-3
DJI Tony
sparkdrone Posted at 4-3 17:00
You're most welcome. Please keep us posted on the latest progress. Thank you!
2019-4-4
sparkdrone
DJI Tony Posted at 4-4 10:56
Actually I just figured out how to do it, thank you for the help.
2019-4-8
sparkdrone
I tried doing it and it worked, thank you.
2019-4-8
nilanjan118
Japan
sparkdrone Posted at 4-8 17:04
Thanks for the update. I was waiting to hear from you. So you can go out and 'ignite the Spark' now (not literally).
Happy flying.
2019-4-8
sparkdrone
nilanjan118 Posted at 4-8 17:10
Happy flying.
OK, thank you.
2019-4-8
DJI Tony
sparkdrone Posted at 4-8 17:01
Hi, we're glad to know that the concern has been fixed. Please let us know if you have other concerns. Thank you for continued support.
2019-4-9
sparkdrone
How do I delete this post???
2019-4-9
jyc
Flight distance : 2255846 ft
sparkdrone Posted at 4-9 16:41
I don't think you can.
2019-4-9
Bing Err
Flight distance : 9249964 ft
I would change your title and subject back to what your original problem was. That way if someone else has the same problem they can find your post and solve it without posting something new. That's why having a large database or solved problems is so helpful. We're literally building a question and answer database every time someone posts and problem and someone else answers it.
2019-4-10
sparkdrone
Bing Err Posted at 4-10 00:48
OK I will change it.
2019-4-10
nilanjan118
Japan
Just as Bing Err said above, you should change the subject line and #1 post to the original for future reference of other members. Just add "SOLVED" at the end of the subject line to let others know that you have found your solution.
2019-4-10
sparkdrone
nilanjan118 Posted at 4-10 18:27
I just did.
2019-4-10
