DJI Tony
djiuser_FPMjZvUBHGyY Posted at 4-17 02:12
Good Morning. I am buying a mavic pro combo, using a galaxy s8 plus and only use the drone on the beach totally deserted, but the control all the time disconnects. Unfortunately I'm not happy about that. I think it's very dangerous! I've done all the DJI Go 4 updates and it still happens. I want a solution, the device is very expensive and I did not use it much, less than 1 hour of flight. Regards Nivaldo
Hi, we're sorry to know about this situation. I would like to ask what error message did you get during the disconnection problem? Was it a "DISCONNECTED" or "Aircraft Disconnected"? If the error message is a "DISCONNECTED" message, this is a connection problem between the mobile device, in this scenario, I would recommend checking the cables if it's properly installed and you may consider using the other port on your RC which is located underneath of your RC. Note: Ensure that the other cable is fully disconnected to avoid connection problem. However, if the error message is "Aircraft Disconnected", I would recommend checking the environment and ensure that there are no interferences to avoid the connection matter between the RC and aircraft. Please keep us posted on the latest progress. |
