Flying High Bro
Flight distance : 25249 ft
Snapped my transmitters antenna
DJI Thor Posted at 4-6 19:33
Flying High Bro, I am sorry to hear your difficulties, it must be frustrated for you. Could you please try to charge the RC to full and try to power on again? When powering on the RC, please make sure that the procedure is short press once and press again and hold on for a few seconds. If it is able to be powered on, please kindly connect the RC and mobile device and check the current firmware of the RC, if it is not v01.04.0500, please try to update the RC again.
If the RC is still unable to start up, if it is convenient, please kindly provide us with a video of the case for further confirmation. Look forward to your reply.
Hi,
I would love to follow your instructions but I literally cant.
When the RC is turned on, it flashes: connecting for 2 seconds.
and then turns itself off.
I can press the power button once, and it shows battery is 100%.
If I turn it back on, it turns itself off after 2 seconds.
I cannot use DJI assistant anymore, because the controller wont stay turned on.
This siutation happened, after I upgraded the firmware to the latest version from DJI assistant. Now it is stuck in this state where it will not stay turned on ever since after DJI upgrade.
