HedgeTrimmer
DJI Stephen Posted at 4-8 11:37
Hello and good day. Thank you for reaching out and for the inquiry. The Warning Messages that you received is a new DJI Go 4 app feature, which can detect the usage of the CPU of the mobile device. This prompt will pop up when the CPU of the mobile device is fully loaded. It is recommended to prevent the mobile device from direct sunlight with a sunshade monitor hood when the mobile device is used in summer. Otherwise the mobile device may warm up and the CPU may be fully loaded, which affects your drone flying experience. Thank you.
"Otherwise the mobile device may warm up and the CPU may be fully loaded,"
Another translation problem? Message should reference SmartDevice's temperature if CPU is getting to hot. CPU fully loaded message would imply CPU is at 100% usage, regardless of temperature.
