hedac
I had the same issue many times... Always at 52% failing. It also happened to me with the first firmware... I contacted tech support (In the memory card you will find some logs for the update that you can send to tech support.) and they told me that I needed to return the unit. But then I tried once more with another phone and it worked! Then I used that same phone to update it without problems to 1.03 and 1.04, but with 1.06 I got the same problem again. But I kept trying...once per day. And it finally updated to 1.06. I don't know why it happens. But I ahve a therory I cannot be sure, but the only difference when it worked is that I had been using the OP for a while... battery was a 30% and it was warm. So give it a try... record something with superfine 4k 25p... make it warm, and try to update again.. No Mimo reinstall, I didn't even had internet connection when I updated it in the middle of the forest.
