PhantomHelp.com
Flight distance : 228255 ft
>> As I was walking back my buddy said it was saying ATTI Mode over and over. Now that I think about it I am guessing it was because the RC wasn't facing the P3?
Either you manually selected A-mode (via the PAF switch) or you were in P-mode and were not connected to enough satellites. If the latter, your Phantom was probably in the process of starting up. It will sometimes take a few minutes to connect to satellites after turning it on. You can read more about the various flight modes in the Phantom manual.
>> I decided to test the RTH, I hit the button on the RC and it started shooting upwards
This is by design. When RTH is initiated, your Phantom will climb to the set RTH altitude and then start moving toward the home point. That altitude can be set in the DJI Pilot application. It's a good idea to always double-check it when flying in a new location.
>> I panicked and started moving the controls. I guess that canceled the RTH.
If you move the left stick after RTH has been initiated, your Phantom should stop climbing to the set RTH altitude and start moving toward the home point immediately. It sounds like you're describing that it just stopped trying to return home. If true, that should not happen.
>> But if I go to Flight Record and click on one it shows a P3 but scrolling under that it says to choose a name for my inspire
Double-check that you're running the latest version of the DJI Pilot application. If using the Android version, you should always download it from the link below since it's sometime more up-to-date than the Google store:
http://www.dji.com/product/phantom-3/download
>> I do know one thing, I need to buy a screen shade.
You can find sun shades here:
http://www.PhantomHelp.com/#RemoteControllerP3
www.PhantomHelp.com
Find the latest must-haves, fixes, mods, how-tos, guides, and accessories for your Phantom.
Phantoms in stock and ready to ship worldwide! (see availability)
