Fausto1991
DJI Tony Posted at 4-10 12:37
Hi, thanks for the inquiry. If the battery has been charged for 20 times then the battery life decreases to 90%. (200-20) / 200=90% You may also check the image below on how you will maintain your batteries. Hope that this information would help you with your concerns.
[view_image]
Thanks for the information,
I consult you,
This formula (200-20) / 200 = 90%, means that the maximum number of charge-discharge cycles is 200 for the inspire batteries?
Also, I ask
Is it necessary to discharge the batteries until you reach a low battery level and then charge it?
Are there problems if I leave a battery between 30% -60% and then the charge to later use it?
I appreciate your comments
regards |
