New Osmo Pocket Firmware Released(2019/04/12)
8774 29 2019-4-12
DJI Support
Flight distance : 2408 ft
Overview
  • Date:        2019.04.12
  • Firmware:        v01.06.00.30 (this firmware is approx. 99MB)
  • DJI Mimo App iOS:        v1.0.6
  • DJI Mimo App Android:        v1.0.6
What’s New?
  • Fixed issue: after updating the firmware to v01.06.00.20, the timestamp on photos and videos was incorrect.
Notes:
  • Use auto calibration after updating the firmware.
  • If the update fails, restart Osmo Pocket and DJI Mimo, and retry.
  • Firmware v01.06.00.20 or later is required when using with Charging Case.
2019-4-12
Femooca
Flight distance : 6919 ft
Brazil
I can not update, always from error.
2019-4-12
DJI Susan
Femooca Posted at 4-12 10:20
Hi Femooca, we're sorry for the inconvenience caused. May I have more details about the issue you encountered? It will be better to offer the screenshot of error message for check, thank you so much!
2019-4-12
Michael Miami Sweden
Flight distance : 24199 ft
Updated without any problems. Seems to work fine.
2019-4-14
Luca Rubino
Flight distance : 711512 ft
I cannot Update. It's really slow to download, and at 64%, always I get an generico error.
2019-4-14
Luca Rubino
I report this:
I tried at home (via WiFi and 4G), and nothing. It was really slow. and always failed.
I tried at office (always via wifi) and I worked very well.
At home I worked with automatic DNS (Italians ISP).
At office, I settled Google's DNS. And it worked.
Maybe could help someone else in the same situation.
2019-4-15
Femooca
Brazil
DJI Susan Posted at 4-12 18:39
2019-4-15
DJI Susan
Thanks for getting back to us. You may check the remaining capacity of the SD card and upgrade again, as it may fail if the capacity is less than 100 Mb. If the issue remains after several attempts, you may export the upgrade log for further analysis: SDcard--MISC/LOG/camera_log.log+gimbal_log.log, thanks!
2019-4-16
DJI Susan
Luca Rubino Posted at 4-15 00:41
I report this:
Hi Luca, thanks for keeping us updated. Glad to hear the unit works well now. Wish you have a good time!
2019-4-16
Femooca
Brazil
DJI Susan Posted at 4-16 00:30
00216584]Delete history success.
[00216609]========== Download: 2019.04.15 11:41:14. boot(0B72) =======
[00216614]Master [02 00].
[00216619][01 00] Firmware download start...
[00285118][01 00] Firmware download finish successfully.
[00285123]Done (103290614B 0x5f073e174f5e19af6a7763934a8891ed).
[00286499]========== Upgrade: 2019.04.15 11:42:24. boot(0B72) ============
[00286503]Packet [C:\OT110_FW_V99.99.99.99.bin] detected, card sn [0x8ab95dfa].
[00286508]Packet upgrade start...
[00286515]Packet checking...
[00286521]Packet vlink 01.06.0030 <-> 00.00.0000.
[00286526]Done.
[00286531]Version checking[1]...
[00286586][01 00][00] v1.8.3602 -> v1.11.3695 need upgrade
[00286697][04 00][00] v2.0.20.14 -> v2.0.22.5 need upgrade.
[00286770][09 00][00] v0.0.0.0 -> v1.0.4.2 need upgrade.
[00286840][09 01][00] v0.0.0.0 -> v1.0.3.7 need upgrade.
[00286913][11 00][00] v0.0.0.0 -> v0.0.2.34 need upgrade.
[00286918]Done.
[00286933]Waiting for user confirm...
[00286943]Firmware upgrading[1]...
[00291072][01 00] Firmware upgrade start...
[00291080][01 00] Firmware upgrade tracecode 0x00010000
[00291086][01 00] Firmware upgrade tracecode 0x00020000
[00305022][01 00] Firmware upgrade tracecode 0x00030000
[00305028][01 00] Firmware upgrade tracecode 0x00040000
[00324528][01 00] Firmware upgrade tracecode 0x0f040502
[00324536][01 00] Firmware upgrade tracecode 0x00020000
[00338480][01 00] Firmware upgrade tracecode 0x00030000
[00338486][01 00] Firmware upgrade tracecode 0x00040000
[00357984][01 00] Firmware upgrade tracecode 0x0f040502
[00357992][01 00] Firmware upgrade tracecode 0x00020000
[00371947][01 00] Firmware upgrade tracecode 0x00030000
[00371953][01 00] Firmware upgrade tracecode 0x00040000
[00376021][01 00] Firmware upgrade tracecode 0x0f040302
[00376029][01 00] Firmware upgrade failed at crc check! [00376034][01 00] Firmware upgrade finish failed (step = 2, err = 0xf2).
[00379039][01 00] Firmware upgrade finished failed.
[00379047][01 00] Camera firmware check error, error count increase.
[00379052]Packet upgrade failed at firmware upgrade, Ret = -1.
[00106121]========== Download: 2019.04.15 11:44:42. boot(0B72) =======
[00106126]Master [02 00].
[00106131][01 00] Firmware download start...
[00190060][01 00] Firmware download finish successfully.
[00190065]Done (103290614B 0x5f073e174f5e19af6a7763934a8891ed).
[00190503]========== Upgrade: 2019.04.15 11:46:07. boot(0B72) ============
[00190508]Packet [C:\OT110_FW_V99.99.99.99.bin] detected, card sn [0x8ab95dfa].
[00190514]Packet upgrade start...
[00190521]Packet checking...
[00190526]Packet vlink 01.06.0030 <-> 00.00.0000.
[00190531]Done.
[00190536]Version checking[1]...
[00190591][01 00][00] v1.8.3602 -> v1.11.3695 need upgrade
[00190706][04 00][00] v2.0.20.14 -> v2.0.22.5 need upgrade.
[00190782][09 00][00] v0.0.0.0 -> v1.0.4.2 need upgrade.
[00190854][09 01][00] v0.0.0.0 -> v1.0.3.7 need upgrade.
[00190949][11 00][00] v0.0.0.0 -> v0.0.2.34 need upgrade.
[00190954]Done.
[00190959]Waiting for user confirm...
[00190968]Firmware upgrading[1]...
[00195093][01 00] Firmware upgrade start...
[00195098][01 00] Firmware upgrade tracecode 0x00010000
[00195104][01 00] Firmware upgrade tracecode 0x00020000
[00208909][01 00] Firmware upgrade tracecode 0x00030000
[00208914][01 00] Firmware upgrade tracecode 0x00040000
[00228242][01 00] Firmware upgrade tracecode 0x0f040502
[00228253][01 00] Firmware upgrade tracecode 0x00020000
[00242061][01 00] Firmware upgrade tracecode 0x00030000
[00242067][01 00] Firmware upgrade tracecode 0x00040000
[00261389][01 00] Firmware upgrade tracecode 0x0f040502
[00261398][01 00] Firmware upgrade tracecode 0x00020000
[00275211][01 00] Firmware upgrade tracecode 0x00030000
[00275217][01 00] Firmware upgrade tracecode 0x00040000
[00294541][01 00] Firmware upgrade tracecode 0x0f040502
[00294549][01 00] Firmware upgrade failed at crc check! [00294557][01 00] Firmware upgrade finish failed (step = 2, err = 0xf2).
[00297564][01 00] Firmware upgrade finished failed.
[00297576][01 00] Camera firmware check error, error count increase.
[00297581]Packet upgrade failed at firmware upgrade, Ret = -1.
[00254503]========== Download: 2019.04.16 08:39:30. boot(0B72) =======
[00254508]Master [02 00].
[00254513][01 00] Firmware download start...
[00323045][01 00] Firmware download finish successfully.
[00323050]Done (103290614B 0x5f073e174f5e19af6a7763934a8891ed).
[00324498]========== Upgrade: 2019.04.16 08:40:40. boot(0B72) ============
[00324503]Packet [C:\OT110_FW_V99.99.99.99.bin] detected, card sn [0x8ab95dfa].
[00324508]Packet upgrade start...
[00324515]Packet checking...
[00324520]Packet vlink 01.06.0030 <-> 00.00.0000.
[00324529]Done.
[00324534]Version checking[1]...
[00324589][01 00][00] v1.8.3602 -> v1.11.3695 need upgrade
[00324699][04 00][00] v2.0.20.14 -> v2.0.22.5 need upgrade.
[00324770][09 00][00] v0.0.0.0 -> v1.0.4.2 need upgrade.
[00324842][09 01][00] v0.0.0.0 -> v1.0.3.7 need upgrade.
[00324917][11 00][00] v0.0.0.0 -> v0.0.2.34 need upgrade.
[00324923]Done.
[00324928]Waiting for user confirm...
[00324937]Firmware upgrading[1]...
[00329086][01 00] Firmware upgrade start...
[00329092][01 00] Firmware upgrade tracecode 0x00010000
[00329099][01 00] Firmware upgrade tracecode 0x00020000
[00343031][01 00] Firmware upgrade tracecode 0x00030000
[00343036][01 00] Firmware upgrade tracecode 0x00040000
[00362541][01 00] Firmware upgrade tracecode 0x0f040502
[00362546][01 00] Firmware upgrade tracecode 0x00020000
[00376493][01 00] Firmware upgrade tracecode 0x00030000
[00376499][01 00] Firmware upgrade tracecode 0x00040000
[00396001][01 00] Firmware upgrade tracecode 0x0f040502
[00396006][01 00] Firmware upgrade tracecode 0x00020000
[00409962][01 00] Firmware upgrade tracecode 0x00030000
[00409970][01 00] Firmware upgrade tracecode 0x00040000
[00429453][01 00] Firmware upgrade tracecode 0x0f040502
[00429458][01 00] Firmware upgrade failed at crc check! [00429463][01 00] Firmware upgrade finish failed (step = 2, err = 0xf2).
[00432471][01 00] Firmware upgrade finished failed.
[00432477][01 00] Camera firmware check error, error count increase.
[00432482]Packet upgrade failed at firmware upgrade, Ret = -1.
2019-4-16
DJI User9048
Flight distance : 1201 ft
Thailand
I want to offer audio adapter can use via wireless module it will be perfect
Because if funny to choose only one.
2019-4-17
DJI Susan
Femooca Posted at 4-16 03:44
Received with thanks! I'll forward to our engineers to check.
2019-4-17
djiuser_exk6nYJRGoCV
Does anybody else have the problem since the firmware update that the OSMO POCLET stops recording after a while? Before the update I could record for as long as I wanted basically, but now it stops after a few minutes, after which I have to press record again and it will continue for even less and less time until it just won't record anymore and I have to turn it off. I haven't changed anything since the update and only record low quality 1080/25p, without any accessories. I formatted my microSD card, reset the camera settings and did a gimbal calibration, but the problem is still there. I have the feeling that the camera might get hotter than it did before the update.
2019-4-18
adamroper
Flight distance : 30135 ft
Japan
djiuser_exk6nYJRGoCV Posted at 4-18 03:43
Did you try more than one freshly-formatted micro SD card?
It sounds like it could be a problem where it's failing to write the data fast enough so it stops (which might be caused by heat). I'd try another card if you haven't already done that. I have had a few micro SD cards that stopped working correctly over the past couple of years.
There are a lot of fake/counterfeit micro SD cards out there that don't always perform as well as they should. It's good to try more than one card if you're having issues.
2019-4-19
GreenFlight
Belgium
Anybody else have this problem  - 10-15% of timelapses starts or finishes with a wrong coordinates - higher/lower of what I chose, tried to recalibrate - still same...?
2019-4-20
DJI Susan
Just to verify, is this the first time when you got the unit? If yes, I'm afraid that you may start a case and send it in for diagnosis: https://www.dji.com/support Sorry for the inconvenience caused.
2019-4-21
DJI Susan
Hi there, you may refer to 14# and try another recommended SD card to see whether it works. Please keep us updated on the latest progress, thank you!
2019-4-21
DJI Susan
GreenFlight Posted at 4-20 04:23
Hi GreenFlight, sorry for the inconvenience caused. May I have some samples for better assistance? Thanks so much!
2019-4-21
Jared Platt
I updated the firmware and STILL, the stupid thing BEEPS every time you start it recording.  I am going to have to return it.  I can't have a video camera that BEEPS when I hit record, everyone looks over to see what the hell the beep was.  This is the most ridiculous feature on the planet.  Will it be fixed in the next week?  If not, I will return it.  A pity since it is otherwise a very cool thing, but the BEEP is a deal breaker for any professional or otherwise self-respecting amateur.
2019-4-22
DJI Susan
Jared Platt Posted at 4-22 23:03
Hi Jared, please kindly update to the latest version and check again. You may check the release note here: https://dl.djicdn.com/downloads/Osmo%20Pocket/20190412/Osmo_Pocket_Release_Notes_en.pdf
Feel free to contact us if there is any further question.
2019-4-23
scann3r
Sweden
Would love to see a option to drift stop when panning (releasing the D-pad on the screen) instead of dead stop in the next fw update. If I dint mistaken this was possible on the first Osmo.
2019-4-25
djiuser_Rjgxqrnq0da4
Hi !
Since i updated my osmo pocket with this new firmware, the file transfer with my PC doesn't work, it's only charging when i connect the usb.
Does anyone have the same problem?
2019-5-2
AweSoul
Russia
Same story. Anything works fine before update.
2019-5-4
Lookonimages
South Africa
scann3r Posted at 4-25 01:28
YES absolutely agree, Please DJI add this back if it was available, The dead stop is not nice at all.
2019-5-6
fans9f5c446b
Flight distance : 17382 ft
After the update I have a sound problem. Can i reinstall the firmware?
2019-5-10
PktShooter
I can't update because my android connector has gone bad, gold contacts after 4 months of use, phone only charges, not connecting to Mimo Apps, can you suggest where to get replacement, extra?
2019-5-14
Hustler66
Yes.. Same problem...
I have tried several recommended cards and still same problem.
Records for a couple of minutes max then automatically stops.
Then there is no recording light and if you swipe screen it says 'Do Not Operate While Shooting'.
If you try and swipe the screen in any direction then you get the error Do Not Operate While Shooting.
Press record and it does nothing.
You physically have to turn off and on the DJI OP to get it working again.
Then works perfectly for a few minutes then the same error..
Absolute Joke.
£330 for something that doesnt work correctly..
2019-5-15
Hustler66
adamroper Posted at 4-19 07:21
I have purchased 3 different memory cards over the past few weeks from Sainsburys where my wife works.
All formatted in the DJI OP..
All U3 A1 or U3 A2 and still the same problem.
2 out of the 3 are different makes and all are different storage sizes.
Not good when you pay £330 for a system and it doesnt work correctly..
2019-5-15
NONA Gugushvili
Georgia
Hi. I have issues with autofocus feature since i received update today. Object tracking is not working. It looses focus every time i start walking and makes video blurry. Tried resetting- but it doesn't help
Before update it was working fine
2019-5-18
David Hassani
Portugal
In DJI Mimo I downloaded the new firmware for Osmo pocket. I use Osmo pocket with WiFi module.
After download I can’t install the new firmware. Pressing on „installation“ nothing happens.
I already deleted the app on my iPhone but this didn’t help.
Could someone help me?
2019-5-24
