GABarber
Flight distance : 94190 ft
After the last firmware update 0400 I noticed that all my pictures and videos had the same date.
Further investigation indicated that everytime I turned off the Smart Controller and turned it back on I ended up with a date of Jan 18, 2013.
I received the following acknowledgement from DJI Support with suggestions to handle until the firmware issue is resolved as below
I sincerely appreciate your understanding and patience. I finally received the update from the engineering team based on the investigation conducted.
The time that is shown on the remote controller keeps showing up each time the remote controller is restarted.
•The cause is a firmware error
•The temporary solution is to turn off the automatically synchronize with an internet time server feature and manually modify the time to the correct time.
•The final solution is to update the firmware.
•The cause of the problem has been located and will be resolved in the next version of the firmware.
