Fuwubuman
Flight distance : 750436 ft
skyeyemedia.gmail Posted at 4-29 11:35
Hi Kim,
DJI was completely useless helping me with this. After lots of testing I discovered that in 1.7.7.0. if you move over 50km away from the location where you did your last compass calibration, you must recalibrate the compass. Soon as you move over 50km away from where you did the calibration the LED will blink yellow-red forcing you to do a calibration. I ended up just downgrading to 1.7.5.0 so I didn't have to deal with this.
Hi,
Thank you for the swift answer. I'll do a downgrade aswel as this is not workable with a big heavylift drone. Next to the fact that it's unsafe in urban/harbor areas. Does the 1.7.5.0 version also blocks taking of when the compass in influenced by steel in the ground in harbours or cities? If not that would be great as i don't like a bird that locks itself. Same thing with the i2 and newest firmwares. Just doesn't fly, only if you do a compass dance. But when you fly off the compass error is now there whilst in flight... :S bad programming i would say.
Thanks again for the reply, did you have to retune the whole bird after downgrade or same settings?
Cheers,
Kim |
