FlyDK
Flight distance : 1636286 ft
Denmark
Actually the exposure value (EV) cannot be changed directly on a Mavic Pro/Platinum. The mentioned wheel is for changing the shutter speed, and the shutter speed should always be about/close to twice the chosen FPS in video if you want the outcome to look the best. The better and more correct way to make the exposure right is using an ND filter.
Set the ISO at 100 for minimum noise, and the shutter speed at 2x the FPS for the right motion blur, and then chose a filter that makes the EV as close to 0.0 as possible. |
