Cetacean
Flight distance : 2528264 ft
Barreira_8 Posted at 4-14 23:17
Bought the drone new, just flew few times always with good weather, definitely something wrong with this one.... I’m going back to the shop and ask for replace/repair, anyway I have DJI care refresh... but really disappointed that an £800 drone gets is lens foggy every time is on.
Aloha Barreira,
The problem is high humidity at some time during the assembly process. The lens cover was put in place during high humidity in a room without air conditioning. You can solve the problem by taking off the lens cover in a room that has had air conditioning running for a very long time or in a very dry environment like a desert. Leave the lens cover off for an hour or two and then put it back on. Problem solved.
We have high humidity here in Hawai'i. My friend got the Obsidian and had the same problem. When you shut off the Mavic Air, the heat from the battery evaporates the condensation, so the problem goes away until the temperature returns to "normal". You could also use this process to resolve the problem. Take off the lens cover every time you turn off the Mavic Air so the condensation evaporates. Fan out the exposed inner area with your open hand and then put the lens cover back on. After a couple times the problem will go away.
Hope this helps!
Aloha and Drone On! |
