NFZ unlock not working
8838 27 2019-4-14
djiuser_C5yg8bux2KWb
South Africa
Hi all.. it seems my unlock not working on M2ED.
I self-unlocked it via website.. but no certificate showing in DJI pilot app.. it does show in the DJI GO4 app but the app doesnt work with the M2ED .. so theres no way to transfer it to aircraft
Please help anyone
2019-4-14
Hi there, sorry for the troubles on self-unlocking the NFZ, we see the Fly Safe Team has replied your email and escalated to the technical team for further information, the team will keep following up, hope the issue will be figured out soon.
2019-4-14
Damager
Flight distance : 9052 ft
I have the same issue all of a sudden - I go through the self unlock procedure in DJI Go on the phone, and it says "Unlocked", but then when I go to take off it simply goes right back to the NFZ and unlock process again.  Did you figure this out yet?
2019-4-15
Kingram
Flight distance : 84085 ft
Did this happen after you guys updated the precise fly safe database update ?
2019-4-15
Damager
Not sure.  There seem to be frequent updates to that database, so perhaps.  Seems strange that a DB change would make the unlock stop working (even though it seems to complete successfully).
2019-4-15
Damager
Tried again today, and it worked fine.  Very strange.
2019-4-16
DJI Tony
Damager Posted at 4-16 16:57
Hi, thanks for the update. We're glad that it works fine now upon trying it again. Sorry for the inconvenience that you had. Thank you for continued support.
2019-4-17
bryn7471
Flight distance : 25118 ft
I have the same problem with unlocking.  I unlock via cell phone text code through website.  It says its good to go.  Take drone outside to fly then I get the unlock screen, check off the 3 boxes, and says unlock successful.  Then I try to fly and it keeps asking for unlock again & again.  Even tried rebooting multiple times, no luck.... So then what I have been doing is shutting it off for a few hours then turn on again, then it allows me to fly, finally!  This has been going on for over a year.  Why is the DJI self unlock been horrible for the past year?
2019-7-25
SullyS
Hi, I cannot unlock the NFZ on the Pilot app. It was working fine until a couple of weeks ago. I've tried the solutions that I have read on the forum but no success. I have also applied for a custom unlock for a restricted area where I will be working next month (approval granted after letter submitted) but it is not showing up on my unlock menu on the app.
2019-7-30
SullyS
SullyS Posted at 7-30 23:58
I am going to be using the M2ED to test its functionality for a large enterprise that intends on purchasing a large number of these systems based on the outcome of the test. Therefore, no being able to fly it will be an issue.
2019-7-30
djiuser_yITbng7knZ7E
Czechia
Hello, we have Mavic 2ED and we are not able to unlock NFZ via sent certificate in DJI Pilot app, resp. we are not able to take-off in the NFZ. In DJI Pilot app is the certificate shown in the list of Other Unlocking certificates as valid, list of Aircraft's Unlocking Certificates is impty. Any advices? Thank you for your answer.
2020-2-6
fans4178fac8
Self unlock never works anymore. 5 hours and 12 attempts of trying. Just says unlocked and then loops back. What’s the issue here!!!?
2020-2-9
rwynant V1
Flight distance : 4842277 ft
fans4178fac8 Posted at 2-9 14:37
Turn everything on,
Tap the 3 dots in the app
Go to Unlocking License
Tap on "Aircraft"
Turn OFF any licenses that are turned on
See how that goes........
Randy
2020-2-12
tyrelljason0gmail.com
Mine kept telling me that the unlock was successful and then prompt me to click yes but once I click yes it brought me right back to square one asking me to unlock and this is a place I've flown before, first time it was not working and I had to go get Wi-Fi once I did that it's still was not working until I updated the Geo maps which I think is the database  that is being mentioned, it took right off but then about two weeks later I went to fly the exact same route taking off from the exact same place for reshoots and the thing is a $2,000 paper weight, finally after I keep attempting to unlock and turning the thing on and off about 90 times it worked but almost cost me the gig, also told me that autonomous features were disable which did not happeN the first time around, making me think I was better off with my old DRONE, WHY DID WE SPEND ALL THIS MONEY AGAIN!?!? ITS A DAMN 2000$ PAPER WEIGHT MOST OF THE time!!!!
2020-2-15
Zakkaari Rokkanno
New Zealand
DJI Mindy Posted at 2019-4-14 19:37
I have applied online for my first ever unlock certificate to fly in authorization zone - said successful
on app - check & refresh Unlocking Licence list
comes up....
No Unlocking Certificate
whats up here?
2020-2-15
Tony Faz
Flight distance : 2379 ft
DJI should have a blanket unlock form to unlock a drone completely.  It is completely unacceptable for those that use their aircraft legally to not be able to take off due to restrictions put into place by a non-authority.
2020-3-2
rwynant V1
Zakkaari Rokkanno Posted at 2-15 22:25
WiFi Hot spot and log into your DJI account and try again.
Randy
2020-3-2
crash1sttime
Flight distance : 1047503 ft
Simple answer, get rid of the MP2 and get the MP1, all the NFZ's can be removed quite easily with a little knowledge, then there is no need to try and use DJI's busted system
2020-3-3
CDobby
rwynant V1 Posted at 2-12 12:47
Turn everything on,
Randy!  Thanks it worked... Too bad I had to wait til I got home and missed awesome footage today!
2020-3-15
rwynant V1
CDobby Posted at 3-15 18:56
Happy to help!!
Randy
https://www.facebook.com/aerial.traffica
2020-3-16
Loreto
Flight distance : 5483068 ft
Portugal
Kingram Posted at 2019-4-15 14:38
I have updated  the precise fly safe database update and the problem is :
www.dji.com/flysafe/geosystem/unlock page is not available, it gives 404 error
I can´t unlock a local blue NFZ I need , in order to have a job done.
2020-5-2
marekmk7
Flight distance : 407247 ft
New Zealand
Loreto Posted at 5-2 06:31
same issue, tried for over 1 hour and was unlocked eventually
2020-12-17
djiuser_m4ioFUoDmhoI
I am having the same issue with the M2 ED. I unlocked with Self-Unlock and Custom Unlock. The DJI Pilot app sees the Unlocking Certificate, I toggle it on, but nothing changes. When I try to fly, it still says NFZ, cannot take-off. Any advice?
2021-4-14
I am having the same issue.
2021-4-14
fans0a35a463
Me too is having the same issues so exactly what is the quick sure fix for this issue?  It is VERY frustrating to repeatedly have to deal with this most every time I want to fly!
2022-4-12
fans77d53e68
Flight distance : 356348 ft
I had same issue today, despite app repeatedly saying it was unlocked. Had to go to website and request unlock. Then it worked. DJI, why offer a broken feature. Time wasted. Unsatisfactory outcome. I will continue looking for alternate US based drone, maybe skydio.
2022-7-6
fans77d53e68
I had same issue today, on m2pro despite app repeatedly saying it was unlocked. Had to go to website and request unlock. Then it worked. DJI, why offer a broken feature. Time wasted. Unsatisfactory outcome. I will continue looking for alternate US based drone, maybe skydio.
2022-7-6
fans2477715f
rwynant V1 Posted at 2020-2-12 12:47
Turn everything on,
This worked for me. Thank you.
2023-6-2
