DJI Paladin
We do appreciate your interest in our products. The motors will stop rotating under the following conditions:
1. The aircraft's attitude is larger than 85 degrees.
2. The drone flies less than 2 m above the ground for more than 1 s (For some aircraft models, such as the Mavic Air, the flight height is 3 m.)
If there is no relative height, the motors will only stop rotating when the aircraft's attitude is larger than 65 degrees and angular velocity is less than 300 deg/s for over 8 s. But in this case you can push both sticks to the bottom inner or outer corners to stop the motors.
It is the same as that for the Mavic Pro.
There are two ways to stop the motors.
1) Pushing both sticks to the inner or outer bottom corners (CSC): Conduct CSC, the aircraft will first turn around, and then stop after 2 seconds. This operation is very dangerous and is not recommended for users.
2) Stopping the motors is allowed when the drone is malfunctioning.
Please note that, After the drone takes off, the method of stopping the motors can be changed.The motors should only be stopped mid-flight in an emergency situation such as if a collision has occurred, the aircraft is out of control, the motor has stalled, or the aircraft is ascending or descending very quickly.
