Broken Arm Piece
1767 3 2019-4-17
Wipeout
Flight distance : 1334275 ft
I broken the small piece that attaches the control arm to the main arm on my I2. I haven't been able to find just that little plastic ring as a single part anywhere. does anyone know the part number, name, or place that I can buy it? If its not possible as a single piece other than buying the whole arm I get it but that seems a bit unnecessary given how it comes off the main arm and seems like it would be easy to replace.
Thanks for looking
2019-4-17
Matthew Dobrski
Flight distance : 1831050 ft
Unfortunately it's not that simple ... Although the motor boom is a 2-part assembly, the clamp itself is sort of trapped within sub-assembly between corrugated ring and motor mount. You'll find small torx screws on corrugated ring, these seem to hold other half of motor boom inserted thru T-sleeve. Therefore the clamp itself is a hard to find item.
2019-4-17
DJI Stephen
Hello and good day Wipeout. I am sorry to know that your DJI Inspire 2 was broken. Since this issue is happened. It appears that this issue needs to be diagnosed by our team. I would recommend you to contact our DJI support team to start up a ticket at https://www.dji.com/support . We have the professional team who would do their best to find out the reason of the incident and then the corresponding resolution would be provided. Please note that the repair fee would depend on the warranty of the product and the outcome of the analysis otherwise, valid charges will apply. Thank for your support.
2019-4-18
djiuser_liExuxrXW8oi
Flight distance : 19633 ft
I had a bent arm from factory
2021-4-12
