David_Harry
Oh-no Posted at 4-21 08:30
Thank you Dave, yes I mean internal mics, for sure if I need wider space, I can connect external binaural setup, what I mean is, if I use the digital recorder alone in general purpose, say work in an environment to capture sound not more than 15 meters away, A-B or X-Y is better? I know I can select those with mechanical adjustable A-B, X-Y, but it will cost much more than my budget.
The main purpose I need are: a) record a meeting, b) record percussion play or some singing, c) expansion recording kit for the OP.
Hi.
A/B without much distance between mics isn't as effective as it is designed for difference in time, this what omnis would work really well with as long as the distance between mics is there. Any X/Y arrangement, crossed pair etc. is designed for time alignment as the mics/capsules are right over each other in the same plane. This only works with cardioids and the stereo field is dictated by the angle used, usually 90 degrees. You can also have spaced (not time aligned) cardioid arrangements that require set distances and angles, crossed or not crossed. Google 'ORTF', this is a specific technique and will give you other ideas of setups, also do a generic google search 'stereo microphone setup technique'.
As for what's better, A/B, X/Y or others, it all depends on what you are recording and what you want. The only proper way to gauge and understand these things is to do a lot of recording and get a feel for what works. It's all good reading about these things but nothing beats practical use and experience. I've been producing audio/music for over 30 years and I still do many test recordings and setups, you never stop learning.
Cheers,
Dave. |
