HereForTheBeer
Flight distance : 5381368 ft
mavic air was a love hate relationship for me, i know Wifi can be alot better and DJI really took a shortcut here with Mavic Air.. both spark and the Air use Wifi 802.11G in its original spec which is extremely limiting.
Wifi 802.111AX (aka Wifi 6) allows for these feature which compete with even Occusync:
realtime channel switching
allows for band hopping
band and channel splitting
4x4 MIMO on beamforming connection
color codes (allows multiple connections on single channel acorss compeiting networks to not interfer with each other)
other devices can act as a node between connections securely (such as future laptops, ipads, iPhoens etc etc on the ground..
mesh networking between hosted connections (basically nodes that connect thru and back to base seamlessly with no additional latency)
splitbandwidth below 10mhz and above 80mhz, including merging techniques allowing for more resistance to interferance and other networks speaking over without large loss in speed
etc etc etc
