DJI Flight Simulator - Unpacking Error
13842 18 2019-4-20
djiuser_seeZXMT069Me
Hi all,
For the second time of trying to install the flight sim I have had this unpacking error, I didn't want to try a third time as Im in the Highlands of Scotland and our broadband connection is slow and metered...
The error is -
007_002 {002/0061}
Any advice or workarounds would be great.
David
2019-4-20
craftycrofter
Solved.. Moral of the story, check its not downloading it to an sd card...
2019-4-20
Hi David, glad to know the issue has been solved, hope you have a great time with Flight Simulator.
2019-4-20
craftycrofter
DJI Mindy Posted at 4-20 19:45
Can you use the mavic air controller?
2019-4-20
craftycrofter Posted at 4-20 22:58
Sure, Flight Simulator supports the DJI remote controllers for the Mavic Air.
2019-4-22
psychodrone
Turkey
DJI Mindy Posted at 4-22 01:20
Hi Mindy
I have problem on simulator.
gives error and cannot find the file.
How can i use simulator.  Can u help me ?
Thanks
I Have Mavic Air&1-2 /  Phantom3-4 Pro / İnspire 1 Pro
2019-4-30
tzant
I have the same error as David. Installing on the main disk of my Windows 10 system (SSD).
2019-7-12
I have the same error as tzant and David.
Installing on the main disk of my Windows 10 system .
2019-9-25
tzant Posted at 7-12 09:10
[view_image]
Hello,
I was wondering if you already have a solution for this problem?
2019-9-25
claudinir
Flight distance : 4354 ft
Brazil
#Quick Reply Here#ola amigos no meu caso foi que tava com falta de espaço no disco  de sistema  confiram e me fala se resolveu ok abraços
2020-2-7
claudinir
Brazil
2020-2-7
pclavounclavito
Hello,
Any advice? I have enough space and getting that error in external hard disk, main disk... Windows 10 running
2020-2-24
djiuser_WUhecfoDrgZ4
Turkey
merhaba benim adım oğuzhan
uygulama inerken hata alıyorum
unpacking error
error:007_002
Yardımcı olursanız çok memnun olurum.teşekkür ederim
2020-3-4
GregLee
Hi all
I've sussed it. If you look at a the screen-shot below for some reason the installer's default location is E:/DFS . It so happens that I have an E:\ drive.... but anyway
The solution is to click "Modify" and create a  new folder in Program Files.
Hope this helps, best , Greg
2020-3-31
fansa99488e0
Flight distance : 66864 ft
South Africa
HI All,
My solution was to put the installer in a folder "DJI" that i manually created in: C:\Program Files\DJI\DJIFlightSimulatorLauncher.exe
Then ran the installer from here and tit worked perfect
Cheers
2020-5-8
djiuser_kytIFj8DLAAd
Flight distance : 1673261 ft
Not easy to get to work but useful once working.
2020-6-21
fans3d8ee3af
Flight distance : 349190 ft
fansa99488e0 Posted at 2020-5-8 23:37
HI All,
Hallo schade ich kann das DJI Simulator trotzdem nicht installieren woran kann es noch liegen Danke schon mal sehr.
1-19 12:24
fans3d8ee3af
fans3d8ee3af Posted at 1-19 12:24
Hallo Schade bei mir funktioniert es auch nicht Sorry was kann man noch machen Danke.ö
1-22 12:04
Lesscan
HI All,
I'm having the same issue.  I tried 3 times after creating a DJI folder like you suggested.  No luck.
4-29 10:54
