Matricks
Hey everyone.
Just recently got the Follow Focus gear for my Ronin-s. Installed works well enough it seems...but then I go to calibrate it and the thing
has an insane amount of torque..it pushes the lens off its mounting slightly and then seems to "find" it's points. But then what happens is
the lens slips gears..its speed is too fast and.
Now, I'm using a Meike 25mm cinelens with gears built onto it. The thing has a smooth long pull range..albeit a borderline stiffer one than most lenses.
Is there a way to manually just set the lens ends in the or by a button press on the focus motor itself? Also I am using the lens support.
Thanks,
