cutis
Flight distance : 1695351 ft
h_brand2000 Posted at 4-21 17:12
I've had the drone for 2 weeks and have flown it 5 or 6 times. Everything worked as it should until yesterday when I discovered the remote would not move the gimble with the wheel anymore.
Ahah! It WAS fine with rc command.
good question is do you recall potential causation(s) triggering it? If nothing out of ordinary could have affected rc command, could it be deleterious environmental conditions subjected onto devices involved? Electronics have convenient take apart junctions making ease replacing boards and appurtenances umbilicaled to boards. Such junctions are atmospherically exposed and due to water vapor plus contaminants they dont conduct well anymore.
Support normally reseats such wiring quick disconnects which miraculously rescrapes good conduction again. Nobody knows your stowage and flying environment. If youre in a dry clean air environment then more likely mechanical wheel fault else doomed electronic fault (its predicted some will fault but not too many). Interestingly, i really am curious how the wheel imparts variation of command electronically. Could be a slit wheel counted by light gate sensor, hall effect fet graduated taper, but not a carbon track po |
