X7 Lens Profile for Laowa 9mm ?
3110 15 2019-4-23
fans863c1916
Flight distance : 31125 ft
I got the new Laowa 9mm with DJI DL Mount for my I2 with X7 ---> https://www.venuslens.net/product/9mm/
Dear DJI, can you create a Lens Profile for this Lens ? Or can we do it somehow ?
2019-4-23
DJI Stephen
Hello and good day. Thank you for sharing this link and this information with us today. As of the moment we do not have an official Lens Profile for Laowa 9mm. Let me please forward this thread to our DJI R&D Team for further development of the DJI Inspire 2. Thank you for your valued support.
2019-4-23
fansc8452019
Hi fans863c1916, Are you are able to control the shutter while this lens is mounted? I can't seem to get control of the shutter no matter what I try.
2019-4-25
Mulcop CEO
Flight distance : 3198504 ft
South Korea
I need it too~ it's so cool lens~
2019-4-25
Coyut
Flight distance : 2559222 ft
Switzerland
A lense profile won't be doable easy, as the Laowa 9mm has no electronic control at all.
But its interesteing that the X7 switches to a ZUIKO.M 8mm profile when its attached.
Sometimes it messes up shutter and iso settings inside GO4 and freezes these options at all.
The best solution I found to fix it, in these cases, is to power it up with a official DL lens and switch the lenses powered up. This restored the shutter seetings for me.
2019-7-10
sincabeza
Flight distance : 2508911 ft
Ukraine
is there any progress ?
2019-7-19
Videoinvolo
Flight distance : 2485869 ft
Xccccccccc
2019-9-17
nik317
Flight distance : 11261506 ft
Switzerland
DJI Stephen Posted at 2019-4-23 10:50
hi stephen, some news after more than one year?
2020-7-13
sincabeza
Ukraine
someone in DJI is still working in Inspire2 project ?
2020-8-23
Coyut
Switzerland
As said before...
The Laowa lens is a fully manual lens. There are no electronics involved. So there can't and never will be a lens profile.
2020-8-23
#FLX
well, what I originally meant was that a Lens Profile would help to correct Lens Distortions, Cromatic Abberations...I guess shutter is not possible because this is part of the DL-Lenses right ?
Of course the Lens has no Contacts, but it would be possible to put a Menu Item under "Lens Profile" wich could be manually selected when one attaches the Laowa 9mm...
another thing that is even more urgent to address with the Inspire 2 Setup is:
make it possible to record the proxy files in HD 1920 resolution and OF COURSE USE THE EXACT SAME FILENAME AS THE SSD FILES - otherwise they are useless as proxies...the best would be if the proxy files could be in ProRes Proxy or LT (for people who bought the ProRes License)
2020-8-23
Coyut
Switzerland
#FLX Posted at 8-23 23:05
Don't look at the h264/h265 files as proxies.
They can be off by a couple of frames.
Sad but true.
I also doubt dji will spend some work for a non dji lens.
2020-8-24
ScooterC5
Flight distance : 435052 ft
Coyut Posted at 8-23 22:33
As said before...
Incorrect, just because this is a fully manual lens, doesn't mean there can't be a lens profile. The only thing manual about this lens is aperture control. A lens profile from DJI to simply 'recognize' this lens would allow the lens to be recognized much more quickly via the Go4 app (currently takes about 40 seconds) and also would keep the video settings from being reset (defaults to CDNG, WB auto, 29.97fps, photos to jpg (not RAW), etc.). All other lenses with a lens profile from DJI are recognized instantly and the settings stick... and there is no issue with adjust shutter on all other lenses as well. Everyone fully gets that aperture control is not possible via the app with this lens.
2020-8-26
ScooterC5
Coyut Posted at 8-24 22:28
Sad but true.
DJI already spent time supporting many other non-DJI lenses like the Oly 12mm, 25mm, and 45mm... They all have lens profiles.
2020-8-26
Coyut
Switzerland
ScooterC5 Posted at 8-26 08:55
Yes, they were supported as their rebranded stock lens is also a Oly and were speaking the same protocol ;)
They also all were electronic.
The Laowa DL is a great lens for some special occasions. But look at the numbers of Laowa DL lenses in use out there. Def. not worth for them.
First they would need to change the app so in case of no dedected lens you could choose manually. But the pins actually give false feedback from the blank metal. This is why you sometimes see a 24mm in the app.
You can also correct anything in post ;)
I'm with you about loosing settings. But were used to that with X7 and X5S anyway. You always have to check everything anyway as settings can and will be lost sometimes.
2020-8-27
AIRWORKS.
Flight distance : 5872635 ft
I have this strange problem where by my 16mm and 35mm when out in the X7 use the profile from the 9mm and until I put the 24mm on then one of these lenses it won’t change, any idea how to fix this it’s really frustrating?
2023-3-1
