C- shape lens cover
767 21 2019-4-24
Oh-no
Could be the best and minimal lens cover, C-shape, plastic, almost no weight and easy to snap on and off, I got mine free of charge together with the aftermarket OP case, but TaoBao China offers two for 20 Yuan.
Highly recomended.
2019-4-24
Oh-no
I suggest DJI to include one of this in the package, good for protecting the lens for daily use, even in the packing itself during delivery. It only cost them few cents for it.
2019-4-24
DJI Stephen
Hello and good day Oh-no. Thank you for sharing this information with us. Great find and thank you for your support.
2019-4-24
hallmark007
Flight distance : 10017858 ft
Oh-no Posted at 4-24 06:48
It’s most likely to late for some, but yes it makes sense .
2019-4-24
hallmark007
2019-4-24
Ray-CubeAce
I would be more concerned about any possible pressure it could have on the gimbal motors when taking on and off than worry about lens scratches. Although unsightly, lens scratches seldom get picked up unless shooting directly towards light sources as anything against a front element is often well out of focus. Heck, I don't even notice fingerprints on the lens of my phone on shots taken. Even then, anything hitting the lens or scraping with enough force to scratch the lens is also a concern more for the gimbal motors as small specks of grit that can scratch the lens could also get stuck the gaps around the motors.
Anyway, I'll keep an open mind as I admit my fears may be unfounded and see how you get on.
2019-4-24
David_Harry
Hi.
Excellent find, perfect for keeping your setup ultra small.
Cheers,
Dave.
2019-4-24
fansfe82067d
I think it would be most unwise for DJI to put these in the package for new users.  If people thought that they could just pop one of these onto the gimbal and then stuff it in their pocket without any other protection, they'd end up with possible gimbal damage, it seems to me.  But if the gimbal is protected, then the lens window should be protected too (by the gimbal cover).  So there's not much point in this device, surely?
2019-4-24
Oh-no
Hi, Ray and fansfe82067d, I agree with your opinion, however, this snap on cover, or should say slide on cover, need only very very small force to slide in, it is far less than pulling the magnetic filter away from the lens.
If someone decided to put the OP in their pocket alone without the case, I will not recommend it. This cover is for extra protection to prevent any dust or debris collected in the case lining, or sometimes you want to lay down the OP for a while on the table or any surface, it is better than rotate the gimbal head to prevent it facing downwards.
2019-4-24
Oh-no
David_Harry Posted at 4-24 12:45
Hi.
Yeah ~~~ it is very practical, it came as a gift with the waterproof case, and I appreciate it.
2019-4-24
Oh-no
Ray-CubeAce Posted at 4-24 12:25
Hi, Ray, regarding minor scratches or fingerprint on the lens surface, I totally agree with you, it does not harm the picture quality at all, because it never came into focus. Normally, I seldom clean the front lens of my camera right the way after it collect some dust, most cleaning will result in lens scratches if not done with care and patience.
2019-4-24
Ray-CubeAce
Oh-no Posted at 4-24 20:43
I do understand that the normal Osmo case is open and in a pocket may get dust, material, ingress from being carried around and could be a concern but equally, I don't know much about the Osmo Pockets gimbal motor bearings or how they work. All I know is they have to react fast and seem to need to be kept in top order. I have been adverse to touch the top half of my Osmo Pocket around the motor area more than is needed to do motion time-lapse or put it back into its carry case and do a very careful clean at the end of a day working with it. My son has bought a lens protective glass screen for his and that doesn't seem to have caused any visible degradation of the video quality, but still, I'm reluctant to go down that route either.
I'm also terrible at losing small items, so personally, I'm happy with less to lose
I still haven't heard from anyone that bought the sunshade for the Osmo Pocket yet either.
I am curious about these things and do wonder about their effectiveness or usefulness but I'm still just coming to grips with using video.
As for keeping a small footprint when out and about. I spent this weekend just using the OsmoPocket on its own for video but found when I got back, some serious problems with my framing ability which I think I should get better at first.  I thought I would be alright as I'm used to doing still image work at events but it turns out it's much harder to anticipate crowd movement in confined areas and shots either getting blocked of footage being ruined by having to move too fast to avoid such problems.
I think next time I am out I will definitely have to use the Osmo Pocket with my phone as well.
2019-4-25
Oh-no
Ray-CubeAce Posted at 4-25 02:19
Hi Ray, Sunshade acts as a sail too .... it catches wind ......
Yes, I am afraid losing small objects too ....... may be one day I will lose the lens cover too.
And practice makes perfect, I am also panning too fast ....
2019-4-25
Ray-CubeAce
Oh-no Posted at 4-25 02:28
My main fear is losing a micro SD card if I need to swap one out when shooting.
I think the Osmo Pockets screen is OK if I can set a shot up in advance but difficult to frame on the go.
I also discovered rather too late that the best mode for me is probably APV for walking around with.
2019-4-25
DJDream
Israel
Thank you for this info.
Is it available online? Do you have a link?
2019-4-25
fansfe82067d
Ray-CubeAce Posted at 4-25 03:06
The trouble with FPV and the small screen is that it's hard to judge if you've got the horizon straight.  So Follow Mode (which should have been called Horizon Lock) tends to work best so you don't have to worry about the horizon, just the general framing of the shot - unless you deliberately want the horizon crooked.
2019-4-25
Tide
South Korea
I was wondering about sunshade too and hearing that it catches wind is hilarious.
Thanks for the info.
2019-4-25
Ray-CubeAce
fansfe82067d Posted at 4-25 18:05
Unfortunately, the other modes have problems as well.  If it's not being able to make the gimble rise when recording then it's too slow to respond to me trying to get the view higher to prevent peoples heads getting cut off in shots or similar. If I have time to set up a shot there is little in the way of problems. It's shooting on the fly that I'm finding difficult.
2019-4-26
jacksonnai
Malaysia
Great idea and suggestion, thanks for sharing!
2019-4-26
Ern
Link to purchase item please
2019-4-26
Oh-no
https://m.intl.taobao.com/detail ... tem_id=589457596481
2019-5-6
Oh-no
One more thing to note, remove the lens cover before you power on the OP, or it will lock the OP and needs reset the gimbal.
2019-5-7
