Tengo este problema
562 3 2019-4-25
Cleibos
Flight distance : 916952 ft
Argentina
What should i do? what's going on?
Check that the aircraft's battery is connected correctly
2019-4-25
Aurelian Irimia
Flight distance : 903350 ft
Las baterías están completamente cargadas? Tienes todas las actualizaciones instaladas? La batería es original?
2019-4-26
M4VERICK8
Flight distance : 500528 ft
Brazil
limpia los contactos del drone y de la batería con los aerosoles limpia contactos.
2019-4-26
DJI Tony
Hi, we're sorry to know about this situation. We've managed to check the error message that you've attached here in DJI Forum. Apparently, the drone would not allow you to take off due to the battery problem. I would recommend checking the pins of Intelligent flight if there's a damage and clean the battery contacts with a soft dry brush. Check whether the battery is properly installed.  If the red part is seen, it means that the buckle on the back of the Mavic Air's Intelligent Flight Battery is not mounted in place. If it's possible, you may try to use different battery to isolate this matter. Please keep us posted on the latest progress. Thank you for your support.
2019-4-27
