Osmo Pocket Filter Sets:
DJI -
ND4, ND8, ND16, ND32 - $49.
Size: 17 × 12.9 × 2.0 mm Weight: 1.2 g
PolarPro -
CINEMATOGRAPHERS CINEMA SERIES ND4, ND4/PL, ND8, ND8/PL, ND16, ND16/PL, ND32, ND32/PL, ND64, ND64/PL - $189.99 LIMITED CINEMA SERIES ND32, ND64, ND32/PL, ND64/PL - $79.99 SHUTTER CINEMA SERIES ND4, ND8, ND16 - $59.99 VIVID CINEMA SERIES ND4/PL, ND8/PL, ND16/PL - $59.99
Aluminum Frame "Lowest refractive index available and a hyper neutral color profile" 16 layers of anti-reflective, anti-scratch, anti-oil & anti-water coatings Magnetic design rated to 35 mph forces Lifetime warranty
STANDARD SERIES PL (fixed), ND4, ND8, ND16, ND32, ND64 - $79.99 STANDARD SERIES ND8, ND16, ND32 - $39.99
Aluminum Frame Magnetic design rated to 35 mph Lifetime warranty
Tiffen -
ND4, ND8, ND16, ND4/PL, ND8/PL, ND16/PL - $79.00 ND4/PL, ND8/PL, ND16/PL - $49.99
Waterproof & Anti-Scratch Multi-Coating "4K High-Definition Optical Glass" 10 Year Warranty
Freewell Gear -
All Day ND4, ND8, ND16, CPL, ND8/PL, ND16/PL, ND32/PL, ND64/PL - $129.99 Bright Day ND8/PL, ND16/PL, ND32/PL, ND64/PL - $69.99 Standard Day ND4, ND8, ND16, CPL (Circular Polarizer Lens) - $69.99 Landscape Grad ND8-GR, ND16-4, ND32-8 - $69.99 Single Filters ND4, ND8, ND16, ND32, ND64, ND8/PL, ND16/PL, ND32/PL, ND64/PL - $19.99 each
IR UV FILTER - $19.99 LIGHT POLLUTION REDUCTION - $19.99 ND1000 – LONG EXPOSURE - $19.99
16 Layers multicoated optical glass lens filters scratchproof, waterproof, Dustproof Lifetime warranty
Budget ND4, ND8, ND16, CPL, ND32/PL, ND64/PL - $69.99 Non-Coated optical glass
PGY-TECH -
MRC-UV (Ultraviolet) - $12.90 MRC-CPL (Circular Polarizer) - $14.90
ND8, ND16, ND32, ND64 - $69.90 ND8/PL, ND16/PL, ND32/PL, ND64/PL - $69.90 MRC-CPL, ND8, ND16 - $49.90 GND (Graduated Neutral Density) ND8-GR, ND16-4, and ND32-8 - $49.90
Size: 17 x 13 x 2.4 (ND/UV/GND) Size: 17 x 13 x 3.4 (CPL/ND-PL Weight: 1g (ND) Weight: 1.5g (PL) Multilayer Hardened Super Waterproof Coating Aviation Aluminum Alloy
SKYREAT -
ND4/PL, ND8/PL, ND16/PL - $29.99 ND4, ND8, ND16 - $29.99 ND32, ND64, ND32-PL, ND64-PL - $39.99 ND4, ND8, ND16, ND4-PL, ND8-PL, ND16-PL - $49.99
Star Filter, Natural Night Filter - $29.99
Multi-coated glass with Reduced lens flaring Aircraft aluminum Lifetime Warranty
SUNNYLIFE - (Is there a official Sunnylife website ?)
ND4 ,ND8, ND16, ND32, ND64 - $13.99 each ND4-PL, ND8-PL, ND16-PL - $22.39 ND8, ND16, ND32, ND64L - $32.99 ND8/PL, ND16/PL, ND32/PL, ND64/PL - $32.99 CPL Lens Filter, ND8, ND16 - $19.99
CPL - $9.99 MCUV - $6.99 Wide Angle - $12.28
Size: 10 × 10 × 5 mm Weight: 2 g
JSR - (Is there a official JSR website ?)
https://www.aliexpress.com/item/Lens-Filter-Set-STAR-UV-CPL-12-5X-ND4-ND8-ND16-ND32-ND64-for-DJI-OSMO/32993979422.html
ND4 ,ND8, ND16, ND32, ND64 - $ ? CR Wide, Star, CPL, UV - $ ? 12.5X Close Up Macro Lens - $11.10
Size: 7 × 8 × 1.4 mm Weight: 3.1 g
ZTYLUS -
Wide Angle 100 Degree (Magnification 0.65x), Fisheye 180 degree (Magnification 0.36x) - $34.99
KASE - (Is there a official Kase website ?)
http://www.kasecn.com/en/show.aspx?ID=1476
10X Macro - $20.98 (Also rebranded as ULANZI?) Wide Angle 18MM - $20.99 (Also rebranded as ULANZI?) ND4 ,ND8, ND16, ND32, ND64 - $ ?
ULANZI - http://www.ulanzi.com
https://www.amazon.com/dp/B07Q9PVKHH/ref=cm_sw_r_cp_api_i_0TKXCbCTACY41
Wide Angle 0.65x - $15.95 (Rebranded Kase?) 10X Marco - $15.95 (Rebranded Kase?)
