jzitt
Israel
DJI Stephen Posted at 4-29 09:08
Hello and good day plmalves. I am sorry for the trouble and thank you for reaching out. Have you tried using a different recommended mobile device to see if the issue will still persist? Upon checking the mobile device Huawei P30 pro. I am sorry to say that the mobile device is still not recommended for your DJI Osmo Mobile 2 as of the moment. Actually, there is a possibility that the Huawei P30 pro will be able to work with the said drone, however, since it's not yet optimized with the DJI Osmo Mobile 2 and with the DJI Go application we cannot guaranteed the stability of the Huawei P30 pro when in use with the said device and with the said application and if this will work all the time while using the specific device. We highly suggest you use the compatible device that was listed on the recommended mobile device list below to avoid any inconvenience and any problem. Thank you.
[view_image]
I'm also using the DJI Osmo Mobile 2 with the Huawei P30 Pro. I'm mostly happy with the results, though it was disconcerting to read your message that they're not officially compatible. I hadn't found any indication of this when first buying them.
The one issue that I have is that, even with the phone slid down as far as it can go, it's still top-heavy, and so shots that should be level tilt by some 5-10 degrees. Is there a workaround for this? |
