Smart Controller Update V01.00.0530 5D button stop working
2090 9 2019-4-29
Mobetterz
Last week:
I updated my smart controller to the new firmware version.
Issue #1
Now the 5D button doesnt work at all.
I have change functions and restarted several times
Issue #2
If the controller isn't connected to the internet the date remains/reset always to Jan 2013
Please let me know how these issues can be solved
thanks
Mo
2019-4-29
ff22
A number of us still have problems with the DATE.  They have not fixed it fully.
Have you tried PRESSING the Power Button for about 10 seconds or a bit more.  That kind of reboots/resets the controller.  If that does not work, you may need warranty repair.
2019-4-29
DJI Stephen
Hello and good day Mobetterz. I am sorry for the trouble. Can you please try to refresh the firmware of the DJI Smart Controller using the DJI Assistant 2. To see if the issue will still persist? With regards to the date that remains/reset always to Jan 2013. Please turn off the automatically synchronize with an internet time server feature and manually modify the time to the correct time. In addition the cause of the said problem has been located and it will be resolved in the next version of the firmware. Thank you for your understanding and support.
2019-4-29
dronie1965
Flight distance : 24971795 ft
Have you found a sollution regarding the 5d button?
2019-4-29
Mobetterz
dronie1965 Posted at 4-29 23:21
Yes, I was in a half state between versions. (Controller updated to version xxx.xxx.53)
dji assist said I was on xxx.004
I noticed when I connected the controller, the message box to allow transferring of file. if you select any option it would disconnect and the dji assistant couldn't see the controller anymore.
Don't select an option. select the background (might close. I didn't try).
Then waited to finish. It updated
Issue #1 is resolved
Issue #2 was resolved by ff22. Press the power once, then hold power to turn on.
I did this for turning off as well
I thank you guys for your quick responses
2019-4-30
D.Raphael
Flight distance : 18275925 ft
Hi everyone, big problems with the smart controller and the go4 app. In flight the go4 app. turn off 10 times. That come since the fw update. Very annoying !! Any one knows this problem ?
2019-4-30
ff22
D.Raphael Posted at 4-30 08:57
Try reloading or refreshing the software.  Assistant has a refresh/reload option.
2019-4-30
Mobetterz
change the display settings
Sleep to never
I had that happen in flight my screen would go black.
Let me know if that worked
2019-5-2
Chesh
Same here, go 4 app keeps crashing on SC since .530 update
2019-6-8
Mobetterz
Date is still somewhat still an issue. probably has to do with no internal clock holding the date and time
2019-6-10
