Wireless + Mic adaptor?
560 2 2019-4-30
jamick
Flight distance : 101988 ft
Can you use the wireless module with the USB-C microphone adaptor?
2019-4-30
RichInGa
Flight distance : 449344 ft
I'd like to have the answer to this as well. I feel like I was cheated already because I could have spent $350 on a GOPRO and had built in wireless ($70) and a port for external mic ($40) -- and then to learn you CAN'T F'ING USE BOTH OF THEM TOGETHER? C'mon DJI That sucks. That really sucks.  Can you please buy mine back?
2019-5-1
DJI Stephen
Hello and good day jamick. Thank you for reaching out and for the inquiry. With regards to your question. I'm afraid that this set up will not work since the port from the wireless module is supported on the charging port of the DJI Osmo Pocket. In addition the USB-C port on the bottom of the Wireless Module is for power only. You can charge your DJI Osmo Pocket when it's placed in the Wireless Module, but the 3.5mm adapter doesn't function while plugged into the Wireless Module's USB-C. Thank you for your consideration.
2019-5-3
