ND Filters and why you want ones with polarizers
652 11 2019-5-6
QuadcopterGuide
Flight distance : 828904 ft
Hi all,
If you are curious as to why you need ND filters, and ones with polarization at that, check out this helpful video:
Do your ND filters for your Osmo Pocket have polarizers?
2019-5-6
A J
Flight distance : 14237874 ft
Excellent info - thanks
2019-5-6
DJI Stephen
Hello and good day QuadcopterGuide. Thank you for sharing this informative video you have created. Great work and thank you for your valued support.
2019-5-6
QuadcopterGuide
DJI Stephen Posted at 5-6 07:50
Hi Stephen, thanks for checking out the video!
2019-5-7
DJI Stephen
QuadcopterGuide Posted at 5-7 02:08
You are very much welcome QuadcopterGuide. Have a safe and happy filming always.
2019-5-7
El Diabolico
For educational purposes only, I would advise folks to bring the CPL filter close to their eye and check the polarization effect before installing it in the camera to avoid stressing the gimbal. It is very easy to get a 'gimbal overload, tap to resume'. Just my 2 cents.
ps. I know that you had to do it in camera as you were shooting a video ;)
2019-5-7
QuadcopterGuide
El Diabolico Posted at 5-7 23:51
hey El Diabolico, great hint. The gimbal can be repositioned up and down by moving it, i think its even mentioned in the manual somewhere but of course the side to side movement is pushing against the motors so u are correct. The Osmo Pocket turns off and on so fast, i normally just turn it off.
2019-5-8
El Diabolico
QuadcopterGuide Posted at 5-8 02:19
You are very welcome, keep the great work!
2019-5-8
QuadcopterGuide
A J Posted at 5-6 03:25
thanks AJ!
2019-5-18
A J
You're most welcome
2019-5-18
GeorgeGreek
Flight distance : 636050 ft
Greece
Thank you for the information!
2019-5-18
QuadcopterGuide
GeorgeGreek Posted at 5-18 09:04
You are welcome George!
2019-5-19
